Home > In Car Electronics > Kenwood Cubby Active Sub Install |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Fits like a glove
29th Nov 2013 7:07pm |
cabell Member Since: 20 Dec 2010 Location: Virginia, USA Posts: 33 |
Looks great. How does it sound?
30th Nov 2013 1:31am |
Sounds really good
But it's discreet which is what I was after. Factory look with no visable wires |
30th Nov 2013 7:46am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 |
Very nice .. neat job and looks a reasonable price on eBay too .. hmm .. May have to do something like this. .. Hoping Santa is going to bring some new component speakers so this would finish off the job. 2008 Defender 110 XS SW - M57N2 / 6HP28X
30th Nov 2013 9:48am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Looks great! Please would you post which model this is and where you bought it.
Is it a KENWOOD KSC-SW11 150 WATT? Ta Merlin Last edited by Merlin on 30th Nov 2013 1:19pm. Edited 1 time in total |
30th Nov 2013 11:03am |
Papa Lazarou Member Since: 11 Sep 2013 Location: West Midlands Posts: 40 |
That looks great Tiger I'll be looking to do a similar thing when I get a sub. And a cubby.
30th Nov 2013 11:13am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Hi Tiger,
The Kenwood website lists the side to side dimension as 280mm and a cubby is only 270mm wide yet your install appears to be the exact width ? Does the Kenwood sub get wider above the base ? |
30th Nov 2013 11:25am |
Yep, I know the dimensions don't add up but in reality it works really well.
When I bought it I thought I'd have a small overhang each side but although it's fractionally wider it doesn't show. Also it fixes through through the cubby from the inside it sits flat. |
30th Nov 2013 11:48am |
Cool, thank you
30th Nov 2013 11:50am |
Been and double checked and base is beveled in so it sort of narrows a touch.
Anyway like I said I took a risk and it worked better than I expected |
30th Nov 2013 12:55pm |
It's a Kenwood KSC-SW11 active subwoofer
Was £119.95, which seems reasonable |
30th Nov 2013 3:39pm |
Thanks, did that come with all the cables?
Merlin |
30th Nov 2013 4:32pm |
All the cables are in the box.
It doesn't have RCA cables included though if you going to use a pre out ( I did) but it does include a cable to splice into your speakers. If that makes sense? |
30th Nov 2013 4:41pm |
Thanks, I've dropped a line to Just Kenwood asking them if they supply the right cables.
Merlin |
30th Nov 2013 5:57pm |
