Home > In Car Electronics > Kenwood Cubby Active Sub Install
Page 2 of 4 <1234>
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Just got hold of one of the Kenwood KSC Sw11 sub's - am i correct in saying that i just need to connect it via the RCA connections on the standard Alpine stereo (2013 Puma)? (sound-wise. I know it needs power too!) My Disco 'best bits'
Defender 110 XS CSW 2013
Post #382339 27th Dec 2014 3:39pm
Should be, RCA's for the audio signals. Power and earth and you'll need a 12v remote wire too, often blue in colour.
Unless it's voltage sensing of which you wouldn't need it.
Post #382349 27th Dec 2014 4:17pm
DiscoStu
Cheers, thanks Thumbs Up My Disco 'best bits'
Post #382351 27th Dec 2014 4:27pm
Thumbs Up The blue remote turn on simply is a switch meaning it's not on all the time but when the HU is on.
Some are even more smart in the fact that the HU can be turned on but in standby with the Amp off but when music is selected or playing it turns it on.
There is normally a wire tail on the rear of the HU a few inches long, it's blue with white tracer IIRC.
Most makes are like this universally.
Post #382367 27th Dec 2014 5:03pm
DiscoStu
All fitted over Xmas - wow, it makes quite a difference! Thanks for your help. The power-on blue/white wasn't a tail, I had to break into it.
I moved my car-pc off of the back of the cubby, lifted the cubby on spacers, fitted the pc underneath, then fitted the sub on the rear of the cubby. The cubby is slightly too high at the moment, but I'll get a bit of ally bent up to hold the cubby at a slightly lower height - it makes a nice armrest at the moment Very Happy My Disco 'best bits'
Post #385523 6th Jan 2015 5:57pm
Yeh I've seen your I'll get a bit of Ally bent Rolling with laughter Fookin CNC engineer Rolling with laughter
Post #385525 6th Jan 2015 6:00pm
DiscoStu
Thumbs Up Whistle
Not as easy any more Crying or Very sad My Disco 'best bits'
Post #385527 6th Jan 2015 6:00pm
munch90
I never ran the blue wire to the head unit just put mine to a ign feed under the seat , so amp is only powered up with ign , and can park up listen to radio on without amp running
think mines a pioneer one
Post #385615 6th Jan 2015 8:24pm
DiscoStu
My amp is running of an aux battery, so no danger of flattening car battery - not that I listen to it with engine off very often. My Disco 'best bits'
Post #385713 6th Jan 2015 10:07pm
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Just fitted the Kenwood KSC-SW11 powered sub-woofer along with Kenwood KFC-E1065 speakers to replace the front LR ones and KFC-E1365s in the rear. These are coupled to Pure Highway H260DBi
DAB Digital Radio/CD with iPod/iPhone Connection and Bluetooth.
Whilst the system is a definite upgrade, I'm still playing about with the setup. The HU has, on the face of it, extensive software controls for tweaking the sound. The KSC-SW11 also has a remote but I'm preferring to use the system without this plugged in and setting parameters on the HU.
I'm getting buzzing from the rear speakers, I am of the opinion that the standard LR enclosures are not up to much and I reckon the enclosures are important for good performance from the speakers.
Overall, better than standard, by far, but would expect more performance. Has anyone, by chance, got a similar setup?
Post #404779 5th Mar 2015 6:30pm
martinfiattech
Brought one myself a while ago, I fitted it up side down to the cubby box. This way you can hide the wires better.
You have to raise the box by 13 mm to route the loom thru. See spacers under the box.
 Excuse the spelling I`am better with spanners and wires.
Post #407091 12th Mar 2015 10:30pm
capnjapseye
A neat installation.
I mounted mine the right way up on the back of the cubby box and routed the wires inside the box, then out the bottom. Also, I found that, with my speaker setup, I tend to get better results with the supplied remote disconnected and adjusting settings through the head unit.
Post #407293 13th Mar 2015 3:34pm
martinfiattech
Thanks, I will give that go.
The other thing is, my stereo is a Alpine bt 136. Which has settings for the sub. My question is. The display states the option to `Reverse phase subwoffer` ??? Has anyone tried this, I`ve had a go but not really noticed any difference. Excuse the spelling I`am better with spanners and wires.
Post #407451 14th Mar 2015 9:57am
capnjapseye
On the remote for the one I fitted (see above) there was the option to reverse phase the SW, didn't seem to make a lot of difference when I tried it
Post #407539 14th Mar 2015 5:01pm
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
Re: Kenwood Cubby Active Sub Install
Tiger wrote:
Fits like a glove Very Happy
Tiger wrote:
Also it fixes through through the cubby from the inside it sits flat.
Did you have to get longer bolts?
I've got one to go one later, the fixing kit that came with it protrudes out past the unit & would lift it off the cubby box, any advice would be greatly appreciated Thumbs Up The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #428339 3rd Jun 2015 1:52pm
Page 2 of 4 <1234>
