Home > Technical > How do you remove the center console on the puma?
Page 2 of 2 <12
Roy5695
Obviously don't get all HULK like on it. As long as the two screws are out of the front it should pull off with reasonable force.
DISCLAIMER: I take no responsibility for your unknown strength and breakages during the above process! Laughing Thumbs Up
I've had mine off many times and haven't broken anything Smile.
Post #460304 4th Oct 2015 12:34pm
Vmesch
Belgium
anyone who has some pictures of the clips at the top? I want to run some cables behind the console to feed my phone/gps installed on top of it... puma 2.2 MY2013
[:O]===[O:]
Post #460424 4th Oct 2015 6:57pm
coxman
Will try this weekend..
Thanks Ray and Eduardo.
I second to Vmesch if someone are doing that and can post the step-by-step photos would be a great help.
Post #460522 5th Oct 2015 12:55am
X4SKP
Hello All
These photos might help...
Remove Torx Screws
Pull back Console from the Top
This may be enough to feed cables through, as I did wanting to pick up a live feed off the heated rear window for the installation of a 13 Pin Towing electrics.
Pull fully Away
Roll to one side (near side is easier) to reveal the 'full' rear wiring and controls.
Good Luck SKIP
Post #460547 5th Oct 2015 8:54am
coxman
Thanks Skip.
it is not necessary to remove knobs and switches and no need to unplug the pins.
Post #460594 5th Oct 2015 12:06pm
X4SKP
Hello coxmax
No, two Torx Screws that's it.
The centre console does locate itself in a few positions these are designed to release and then relocate
when re-fixed. Pull gently and evenly across the top of the Console... Thumbs Up
Heater / Air Conditioning Controls Stay behind
Clock and Push Buttons and Radio come forward
 SKIP
Post #460636 5th Oct 2015 1:19pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Clips on sides:
Clips on top at edges:
Post #460690 5th Oct 2015 3:57pm
Vmesch
Belgium
Great, thanks X4SKP and all of you... Bow down
Have any of you ever had problems fitting all the wiring back in place? Looks like a bunch of wires there Whistle
I'll have a try next weekend! puma 2.2 MY2013
[:O]===[O:]
Post #460769 5th Oct 2015 7:19pm
Happyoldgit
There are times when you just have to bite the bullet and get stuck in, no end of questions and answers will cover all the possible permutations and possibilities
...just ask Zagato [only old timers here will have the faintest idea what that is about] Laughing Steve.
http://forums.lr4x4.com
Post #460837 5th Oct 2015 9:21pm
Personally I'd recommend removing the HU first then the dash.
Otherwise you're much more likely to damage the HU, mounting or dash.
Refitting I would do the reverse as you'll likely get trapped wires.
Post #460840 5th Oct 2015 9:28pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Thanks for the pictures, at least we can see where it is hold.
Regards,
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #494445 20th Jan 2016 2:42pm
sjwdrew
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
It is just the 2 screws, I did mine this morning, slightly nervous but it came away pretty well. Replaced a few bulbs that had blown (that was more difficult, fiddly things Evil or Very Mad )
Good luck
Thumbs Up
Post #593645 16th Jan 2017 8:56pm
Page 2 of 2 <12
