![]() | Home > Puma (Tdci) > Lack of power |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Is the egr fitted? I presume so if you had the chucka chucka noise on shut down. The get can be disabled during driving but then still carries out the cleaning cycle on shut down. Maybe during the cleaning cycle it's stuck all the way open?! Or is wasn't programmed out in the first place and is now broken.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
On a TDCi the EGR will not have been removed, merely turned off in the s/w.
Some remaps turn it off altogether, some leave the cleaning cycle on shutdown still active. If you used to have the chukka chukka after the remap, then your map is still ordereing the cleaning cycle which is, of course, operating the EGR through its full range of movement. It is quite possible therefore that it has failed, open, during the cleaning cycle, whcih woudl undoubtedly cause the symptoms you describe. If so, you will need either to remove and clean the EGR in the hope that is starts working again, or replace the EGR. (I suppose that you could possible fit a blanking pate in the exhuast gas passage and leave the EGR alone as well). In my opinion there is no point in having the cleaning cycle if the EGR is turned off in the map unless you intend to remove the map and reactivate the EGR. If you don't, it is simply asking for this failure mode to occur. |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
Thanks for the replies. Just back from Landranger garage at Atherton where Martin very kindly gave me five mins and plugged his tester in to confirm as you have
Might be of some help to others...
Took all of ten mins to whip off the EGR ![]() There seems to be a blanking plate on my EGR? So I'm assuming that the ECU is asking for a return signal from the EGR (that is fooling the ECU into doing it's job) to keep it happy? |
