Home > Puma (Tdci) > Slick shift tdci?
Page 1 of 7 1234567>
bear100
Slick shift tdci?
Slick shift for a tdci? Is there such a thing and does it make much difference? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #457517 23rd Sep 2015 2:41pm
hornet
Post #461302 7th Oct 2015 2:03pm
hornet
Re: Slick shift tdci?
https://secure.bellautoservices.co.uk/stor...lickshift/ Thumbs Up
Post #555230 11th Aug 2016 7:39am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Just bought one for my TDCI and going to fit it this weekend so will find out soon. Reports I have heard so far are very good.
Post #555242 11th Aug 2016 8:27am
Av_ Dave
Interested to see what the review is like on these.
Post #555264 11th Aug 2016 10:18am
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I'm interested in user feedback too as I've been mulling this mod over since having a look at it on a static gearbox on the synchro stand at Billing. it kind of solves a problem I don't have but I can still justify it to myself based on one or two uphill/low box type scenarios where momentum can get lost in a slow gear change.
One reservation I have and I ask the experts on here; what's the general view on whether this mod is going to be good for the gearbox long term? in my own experience the puma box doesn't seem to like to be rushed and I imagine (but could be totally wrong) that this mod, by its very nature and intention, is basically rushing the box albeit, because of the change of pivot etc., doing it in a predictable way.
Interested in thoughts all round.
Post #555289 11th Aug 2016 11:30am
Av_ Dave
That's a good point, unless this has been taken into consideration with the design of the shifter?
Post #555299 11th Aug 2016 11:45am
Wandathe110
There not listed but he's just released them for the puma message Shabs Percy he'll sort you out
http://www.syncrogearboxes.com/shop/defender-slickshift/
Post #555313 11th Aug 2016 12:22pm
Leaky 110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Sort of related question while we're talking about kits like this.....
My puma gets a bit cranky with changes between first and second, it feels exactly like knackered synchromesh in my old series 3. Do defenders suffer the same problems or is fitting a kit like this likely to be the solution?
Maybe hopeful thinking but I'd hoped they'd ironed out synchro problems after all this time!
Post #555318 11th Aug 2016 12:40pm
Scoobeenut
I think the problem is that the OEM linkage becomes progressively worse over time because the plastic parts wear and split causing the shifting to become vague and sloppy. The new linkage seems to be much better engineered with better tolerances that should prevent this happening. I think that we still need to be sympathetic when changing gear owing to so many moving parts within the transmission.
Post #555319 11th Aug 2016 12:41pm
Leaky 110
Thanks for the reply, I'm having bad dreams about gearbox rebuilds!
When I bought the puma I was surprised at how slow and deliberate the changes had to be to prevent crunching! Glad to know it's likely to be something simple to fix!
Post #555325 11th Aug 2016 1:05pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I got myself one of these kits last week and fitted it over the weekend. The gear change is a lot shorter now, I'd say distance between first and second is about the distance that it used to be from first to neutral.
It makes the gear change a lot better and feels much more like driving a modern car, allowing you to get up the gears much quicker.
You do however have to use a bit more pressure to engage gears due to the decrease leverage but, although it is noticeable, you get used to it pretty quickly.
I didn't really have any gear change issues before fitting the kit so can neither confirm nor deny if it will fix anybody's problems but I did notice that the nylon "ball" on the old shifter had cracked, I've also seen pictures of other people's balls ( Rolling with laughter ) that have completely disintegrated which probably could lead to issues? The slickshift does away with the nylon ball and has a machined stainless ball instead.
Oh and I almost forgot, before the mod I didn't have a rattly gear stick that some people experience, however with the reduction in throw there is an increase in vibration through the gear stick which meant that I had to remedy the rattle with some glue. There's plenty of threads on here that cover how to do that, just worth considering so you don't have to take the stick off twice. Thumbs Up Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #555364 11th Aug 2016 5:06pm
Gaz
United Kingdom 1994 Defender 110 300 Tdi HT Pennine Grey
Hi no need to glue the weights on the gear stick,Just put a couple of zip ties around the base of the gear stick.This solves two problems in one..It stops the weights annoyingly buzzing and secondly ties the locating ears together for more solid location.
Happy crunching ..i mean gear changing... Thumbs Up
Post #555372 11th Aug 2016 5:50pm
Happyoldgit
It's a truck Rolling Eyes Steve.
http://forums.lr4x4.com
Post #555423 11th Aug 2016 8:25pm
Naks
keen to get one, but the Puma version is 165 pounds vs 75 for the Td5!?? Shocked --
Post #555522 12th Aug 2016 9:04am
