Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 8 of 11 <123 ... 78 91011>
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Dale,
A belated thanks for your reply. Sussed it out yesterday.
Rob
Post #428276 3rd Jun 2015 8:05am
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
Thumbs Up
Post #428302 3rd Jun 2015 10:12am
Jeff 8
Australia 1998 Defender 110 300 Tdi SW Chawton White
My 2015 SW doesn't have the spare purple wire, a purple wire goes to the heated rear window. I also found a power one on all the time going to the trailer plug, but I want an ignition switched one, so will keep looking.
The blue one. I think Shocked
Jeff
:cow:
Post #430141 11th Jun 2015 1:30am
bluebottle
Done mine today, not the neatest but it works!
Post #430669 13th Jun 2015 3:06pm
duncagr
Great write up - I'll be doing this before my camping trip this year. Like the rear speaker location too, I thought I would have to put them up in the top corner on a custom mount but that looks much better.
Post #437677 14th Jul 2015 3:14pm
munch90
Jeff
Cow
can be done by using the ignition feed to the rear wiper motor to switch a relay mounted in the back and using the permament live you have , this way wiper ign feed has no extra load apart from switching relay and load from aux socket will be on the wire you have spare in trailer plug and will go on and off with ign and no need to have any extra wiring running to front extra
BUT CHECK YOU HAVE THE RIGHT WIRES TO DO IT , IF YOUR NOT SURE GET SOMEONE WHO IS !
Post #437887 15th Jul 2015 5:58am
adm2243
Wales 2015 Defender 110 Puma 2.2 XS CSW Indus Silver
Great guide - I shall be having a go at fitting one in mine at the weekend. Smile
Post #442713 3rd Aug 2015 12:03pm
Orchard
Great, easy and practical, one for the growing list of things to do ! Laughing
Post #444041 7th Aug 2015 3:59pm
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
Found it!
originally looked behind speaker on my 04 Defender could not see it. Just replace the stop and tail bulb and there it was. Just fitted it handy for my small extension light (freebe from the AA some time ago.) thanks for the info Eric
Telshe
Post #455889 17th Sep 2015 6:02pm
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
The speaker panel you installed this in, are they a universal fit throughout all Defenders? I'd like to get hold of a pair for my wifes TD5 90 if they are as there's just the bare rear panel showing at the moment. Great how to by the way, most informative.
Post #479341 5th Dec 2015 1:17pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
I've been looking at installing tow bar electrics to the 2015 SW. The purple wire and black wire behind the right hand speaker pod are omitted on post 13MY models, as previously mentioned.
On the standard 12N wiring kit (britpart/OEM) the purple wire continues through the trailer socket wiring and terminates in a connector, along with the reversing light feed in the void behind the plastic mud shield at the rear (the red wire in the photo below).
If a wire with a spade connector is dropped through the small hole alongside the main grommet and connected to this branch of the trailer wiring, this could be connected to an aux socket. The negative could be spliced into some of the earth wires for the adjacent lights, no?
 Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #505280 16th Feb 2016 7:51pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
CDN38 wrote:
Purple wire is there on my 2000 110 CSW. (BOY I LOVE THIS BOARD!!) Does anyone know what the orange plug is for?
I found this wire and ran my multi-meter across it (the purple one with the moulded connector shown in the picture above).
Trouble is I am only getting a reading between 0.35V to 1.4V....
I am stumped!
Sounds like a short of some sort, or more likely a bad connection, but I'm not sure where? I have tried various earths, and I have a solid earth connection, so its not a earth fault.
Any ideas?
Andy
Post #506825 21st Feb 2016 9:01pm
babybimmer
China 2014 Defender 110 Puma 2.2 SW Aintree Green
Nice writeup!! Thank you, will try to do it lately.
Post #522922 10th Apr 2016 11:27pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
So as a few have said, the later models don't have it, I have 13 pin electrics that I wired up but don't remember seeing a spare wire, I've removed and broken a few plastic screw things but I can get those from halfords. My question is this, are there any other points in the rear where it's just a plug and play piece for aux? I bought a ford aux socket as it matches up perfectly but I now don't have the wire...
I can see a purple under the wheel arch from my 13pin electrics (photo) being utilised... So I'm stuck
Post #529745 7th May 2016 2:40pm
splatt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Many thanks, finally got round to this in my 2008 110.
First ever real modification I've done on my Defender so learnt how some of the trim comes off and those awful plastic screw/clip things!
 2008 Defender 110
Post #548490 13th Jul 2016 3:58pm
