Home > Puma (Tdci) > Blue smoke on start up....
Page 4 of 4 <1234
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Martin been thinking about your cheat idea....
The problem is with No4.
Because No3 has been loosened / cleaned and a new washer installed when I start it up won't that No 3 injector just pop up and reduce the pressure on No4 thereby not giving it enough pressure to lift it (No4) or am I talking b......ks?
Jones the willing to give it a try Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #424678 19th May 2015 7:41am
hornet
[quote="jonesie"]Hi Yolo,
Just turned over the 50,000 it's a 2008 ......... Pre engine mod / service bulletin but not rattling.
Had the management light come on a couple of times lately and the egr valve doesn't always make the chugga chug on shut down.
Have been using shell V Power whenever possible but occasionally run regular ( when not able to fill up with shell.)[/quote]
When the EGR is not working constantly its time for an EGR-Change, had the same problem last month. The MIL-Lamp came but dissappeared after a while. In combination with the EGR-change i also cleaned the MAP-Sensor and LMM-Sensor (measures the amount of air in intake). Both are very easy to clean, but be careful with mechanical cleaning, use a solvent only.
Post #424796 19th May 2015 3:41pm
jonesie
Was yours smoking on startup Hornet? Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424822 19th May 2015 5:18pm
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
Hello all!
Just got here by searching for "blue smoke". Smile
There is so much knowledge here in Defender2.Net. I love this forum!
Well, my 110 2008 is also blue-smoking on start up, no matter what the external temperature is (cold/warm).
The blue smoke appears with the engine cold. Once it gets warm, smoke is gone.
I noticed the EGR noise is becoming louder with time. Had it replaced about 2 years ago. When I turn the engine off, the 'cleaning cycle' is done almost always, but I notice it is kind of getting harder to complete. It is like if the valve is slowly getting stuck, which, IMO, is a matter of time for any EGR in the world. Smile
I also thought about removing it for cleaning, but it seems impossible to get to the screws without removing the engine.
Anybody here who has done this job (removing for cleaning or even replacing for a new one) can tell us how hard it is? A how-to would also be much appreciated, of course. 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #453434 8th Sep 2015 8:00pm
Eau02467
It's easy enough to remove provided the jubilee clip that attaches the exhaust gas cooler water pipe on is not obscuring the bolt. It's also really easy to clean and I would recommend a lot of lithium grease on the gears, mine was really bad but once cleaned and greased it is like brand new. Also stopped startup blue smoke
Post #453483 8th Sep 2015 9:58pm
AlexSmith
Awesome!
I'll try it out and, if possible, take some pictures. I believe it would be nice to have a step-by-step procedure, considering almost everybody face this issue sooner or later.
Thanks a lot for the all the info! 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #453489 8th Sep 2015 10:07pm
Page 4 of 4 <1234
