Home > Puma (Tdci) > Blue smoke on start up....
Page 1 of 4 1234>
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Morning all,
I have quite a lot of blue smoke being emitted out of the exhaust on startup.
I wasn't to bothered during the colder weather as I thought it was just the system riching up prior to start up.
However now its warmer I still get the quite large puff of blue smoke on startup which then dissipates as soon as I move off.
Could this be anything to do with the EGR starting to block up or the maf sensor?
Thanks all.
Jones the smokey Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #417504 20th Apr 2015 8:47am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
My EGR is dying a slow death, the last few weeks has seen a big change in noise during switching off, and you can hear it operating when coming to a stop, making some real random squekey noise,
But since it's been playing up I have noticed blue smoke on start up too!
I'm replacing the EGR this week, so will let you know if it cures the smoke problem. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #417530 20th Apr 2015 10:39am
jonesie
Thanks Ian.
Who you getting to do it?
Doesn't look as easy as stuff we have to do on the SI's
Jones currently in Cyprus where it's 18degs and slightly overcast. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #417537 20th Apr 2015 10:58am
ian series 1
I shall be doing it one night at work!
Give me a 2ltr side valve any day Laughing 80" 80" 86" 88" 90"
Post #417592 20th Apr 2015 12:47pm
dgardel
Italy
Check the injectors seal Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417605 20th Apr 2015 1:21pm
jonesie
Yeah dgardel I had quick scan of the seals and there is no external oil / black sludge leaking out.
Could they be sucking in air which could affect the mixture?
How easy is it to replace the seals do they just lift out? Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #417727 20th Apr 2015 8:03pm
dgardel
Italy
If the leak is small, especially when the motor is cold the engine suck oil from the head (cams area) and at the beginning of the leak you cannot see anything outside
but it is only a supposition
is the engine eating oil?
the egr valve that does not close completely may be the cause also
let me know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417808 20th Apr 2015 10:31pm
jonesie
Yes it's eating oil, used about 1ltr over 1500 miles (approx 2400 ks)
Jonesie Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #417844 21st Apr 2015 7:27am
dgardel
Italy
mhmmm...
Normally Puma engines doesn't eat any oil.....
it is better check the injectors seal (the lower ones, the copper washers)
It's not an easy job, you need to "use" a good diesel systems workshop.
Let me know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417848 21st Apr 2015 7:44am
YOLO110
Australia
How many k's has your Puma done? VERY unusual for any oil consumption at all... Shocked YOLO... You Only Live Once...
Post #417849 21st Apr 2015 7:47am
jonesie
Hi Yolo,
Just turned over the 50,000 it's a 2008 ......... Pre engine mod / service bulletin but not rattling.
Had the management light come on a couple of times lately and the egr valve doesn't always make the chugga chug on shut down.
Have been using shell V Power whenever possible but occasionally run regular ( when not able to fill up with shell.) Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #417862 21st Apr 2015 9:02am
jonesie
Sorry Yolo that's miles so approx 84 thou Ks Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #417863 21st Apr 2015 9:04am
dgardel
Italy
mine 2008 has 110.000 km, 180CV from new without any oil consumaption
250cc of 2SO every full always
"knocking wood" Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417865 21st Apr 2015 9:11am
dgardel
Italy
dgardel wrote:
mhmmm...
Let me know
also controls the values of the cylinder compression.
If the copper gasket does not seal the injectors, also the compression will be a little bit less (assuming that the cylinders and valves are in working order) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417866 21st Apr 2015 9:15am
jonesie
Guess in need to get a compression test done then go from there by the sound of it dgardel.
What should a good cylinder be registering? Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #417889 21st Apr 2015 10:52am
Page 1 of 4 1234>
