Home > Puma (Tdci) > Blue smoke on start up....
Page 2 of 4 <1234>
dgardel
Italy
25-26 bar (380-390 Psi) at about 6-10 cranks Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417898 21st Apr 2015 1:01pm
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Evening all I might have a small bit of good news...
Firstly thanks for your advice dgardel I will log the compression rates in case I need them at a future date.
I took the Landie down a couple of junctions of the highway to hell today (m25) and revved it quite hard holding it in the gears, actually got it to nearly 4 thou on one occasion but won't be doing it again. It just felt wrong.
However when I got home I took off the plastic top cover and inspected the top injector seals with a very bright lamp,
piston 1 and piston 3 both had a small amount of oil weeping out of the top......
Not sure if this the cause of my problems or not but will get some seals and see if anything improves.
How difficult a job is it? Is it just a case of popping off the electrical connectors and unscrewing the top of the injectors?
Thanks jones the fingers crossed Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #418034 21st Apr 2015 9:11pm
munch90
No not as simple as that
whole injector needs removing , DO NOT UNSCREW TOP OF INJECTORS
the seal he is talking about is the copper washer at the bottom of injector not the rubber seal at the top
Post #418040 21st Apr 2015 9:24pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Be carefull of the little green "O" rings on the leak off pipes they can be very delicate Whistle 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #418048 21st Apr 2015 9:40pm
jonesie
Thanks munch,
Ok so is the oil seeping out of the rubber seals at the top the possible cause of my oil loss / blue smoke on startup or is it the lower copper seals that have gone which is causing the rubber seals to weep? Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #418049 21st Apr 2015 9:40pm
munch90
yes if the copper seals blow it would blow up against the bottom of the rubber seal possibly causing bit of oil pushed out seal , to be using 1-2 litres of oil the top of engine would be covered
as ive said before , leaking copper washers are rare on the transit engine , ive personally never had one leak , there was a pic on forum somewhere of 1 injector out of 4 removed that was blowing thats the only one ive ever seen , but of course this would depend on mileage, past history etc of that engine
trouble is its best part inpossibe to tell which one is blowing if only blowing slightly even on compression test as compression your checking is no where near firing pressure
even if you find which one it is , your have to do 2 , as one clamp holds 2 injectors and if you release pressure on clamp then your need to do both
if one is blowing then you may (good chance you will ) need to clean the injector seat with special seat tool
so really its do all 4 ,
Its not hard , but they are some specialist tools needed , washers and seals , new clamp bolts arent expensive and really should only be 1 or 2 hrs labour with the right tools , know how
MY ADVICE IF YOUR NOT 100% SURE YOUR ABLE TO DO IT , GET SOMEONE WHO IS Thumbs Up
Post #418060 21st Apr 2015 10:00pm
jonesie
Ok bit more involved than the old td5..
Can you recommend anyone in our area ? ( I am over in Ascot .)
Ta Jonesie. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #418062 21st Apr 2015 10:06pm
jonesie
Ok parts ordered of Dan. ( 4 x injector top seals 4 x copper washers )
Came out more than I thought though £103........the washers cost a fortune but he always does his best for def2.
Booked in in a couple of weeks so let's hope this solves the problem.
Currently when I start it up from cold it's like a coal fired power station coming on line for the first time.
Back in Cyprus which is warm today. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #419683 28th Apr 2015 10:12am
jonesie
UPDATE
Firstly having bought the copper seals off Dan I returned them....at £16 ish each after discount they went back and I bought some off the bay at £5 for 4 delivered.
I watched / helped / hindered my local Indy this morning and replaced the rubber top seals and copper bottom injector seals.
We cleaned up the seats in the head and reinstalled everything and what a difference it seems to have made it pulls well now.
The ebay washers where softer than the original washers which came out so hopefully they will seal better.
All the old seals had signs of blowing.
However......
No's 1 & 3 had oil leaking out of the top rubber seals which had got worse since I started the thread.
The plan was to do all 4 but he / we could not get the 4th injector out, the other 3 just wiggled / pulled out relatively easily but No 4 despite moving slightly left to right would not lift. He didn't want to lever it out and fracture the rocker cover so we left it as is and because it was dry in theory it did not need replacing.
Having watched him I now I would like to replace No 4 myself which leads me to the question .. how are the injectors pulled out ?
If they are stiff is there a special tool?
Jones the pulling much better lol
Also does anyone know the torque setting for the two stretch bolts that hold the injector clamps in place? Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424408 18th May 2015 12:49pm
jonesie
Thumbs Up Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424409 18th May 2015 12:52pm
Bottom tool on this page.
Not sure of the torques offhand, I am afraid.
Post #424412 18th May 2015 1:00pm
ian series 1
6 nm then 180 degrees, that's what I do on the transits. 80" 80" 86" 88" 90"
Post #424416 18th May 2015 1:05pm
Edit - Please ignore my earlier answer - my head was in TD5 mode not Puma. DOH !
I've just checked the WSM for the TDCi. Torque is exactly as Ian S1 has said.
As far as removal is concerned, the manual simply says "remove the clamp", then "remove fuel injector" so no special tool or slide hammer is (supposedly) required.
The JLR Workshop Equipment catalogue as far as I can see lists nothing.
Post #424418 18th May 2015 1:10pm
jonesie
Thanks Ian and Black Wolf
Must admit Black Wolf I haven't been able to find any tools/tips searching the tinternet.
It just will not pull up guess the carbon is blocking it pulling free....... Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424425 18th May 2015 1:41pm
ian series 1
You will find these injectors will either just pull out, or they have stuck solid!
Get a spanner around the 2 flats and give it a wiggle from side to side.
You need to show them who is boss but they will come out.
If not, get a good pair of grips on them and try to pull as your turning it.
It will come out in the end! Thumbs Up 80" 80" 86" 88" 90"
Post #424430 18th May 2015 2:13pm
Page 2 of 4 <1234>
