Home > Maintenance & Modifications > Increasing reverse light illumination
Page 5 of 7 <1234567>
Pickles
Pretty impressive improvement Eric!
Pickles.
Post #422127 8th May 2015 10:22pm
mk1collector
Hi Eric, do you know if the wires for the light went through the existing washer jet hole or were three holes drilled, two for mounting and one for wires?
Cheers Thumbs Up Ray
My build thread
Post #422129 8th May 2015 10:30pm
ericvv
Not sure of that Ray, as I left it to the service department of my dealer, and I did not want to stand on top of them. The most important for me is that they used everything that I provided, most importantly the stainless fixings, the Duralac anti-corrosion paste (they know that tube very well by now from a few other jobs Laughing ), and also the foam gasket which comes with the light.
I could have done this by myself, but my dealer is a quite good one here, and I feel more comfortable to leave them loosening up the headlining at one side from back to front, and put it properly back. Matter of fact they broke a few of the headlining plastic fixings in the removing process, but the good thing again is that they have the original replacements for that in stock then again. I got both headlining and rear trim back clean and as firmly fixed up as before. They know I will be checking all that. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #422134 9th May 2015 5:23am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Cheers Thumbs Up
Hi, I put my light in the same position as Eric's
The connectors for the S17 are roughly central on the lamp unit, but I had to enlarge the washer jet hole slightly to get the wires properly lined up when I had the lamp in the "ideal" position.
Post #422154 9th May 2015 8:03am
mk1collector
Thumbs Up thanks for the info guys, I think I need one on my 110 so the list gets longer yet again Big Cry Ray
My build thread
Post #422168 9th May 2015 8:43am
dgardel
Italy
from the cubbybox switch (ON-OFF-ON) you can choose:
1. ON
2. always OFF (centre position)
3. ON with Reverse
From the rear switch (ON-ON)
1. as "decided" from the cubby switch
2. ON
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #422217 9th May 2015 1:44pm
tasr12
England 2002 Defender 110 Td5 CSW Zambezi Silver
I like the look of this, how much would a dealer charge to fit and wire this in? I've fitted work lights to my last 2 vehicles but I'm keen to keep the latest addition (albeit a 2002) in good shape. Any advice for somewhere to fit
it around Blandford/Salisbury would be very useful.
Thanks. 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD
Post #447905 21st Aug 2015 4:15am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I'm running double S18's, it's a serious amount of light. I went with the same configuration as mark_d. Makes backing up (and camping so much easier)
Post #447916 21st Aug 2015 6:01am
tasr12
Tricky,
I was originally thinking one of these two:
http://www.ebay.co.uk/itm/390813112667?_tr...:MEBIDX:IT
http://www.ebay.co.uk/itm/27W-Spot-BEAM-LE...0813112667
Obviously a step down in price but then they are both around 27w in output where as the Scenelite S17 is a total of 12.5w. Am I missing something? Or is it that the lumen output of the Scenelight being 1400 will make it brighter?
Apologies for the stupid question!
T. 2002 110 CSW TD5, Zambezi Silver
Post #447954 21st Aug 2015 8:50am
Cupboard
Lumens is a measure of light output, watts is a measure of power.
One does not directly relate to the other.
Just because something is higher powered doesn't make it brighter, it might just be more inefficient.
The two you link to don't list a lumen rating. One is also listed as a "spot" which you really don't want for a worklight.
Post #448108 21st Aug 2015 6:17pm
I used to have a pair of the Wipac (first link in post above) and although ok they weren't very bright, and after about three years the rubber housings had perished so you got black if you touched them and the light tended to fall out of the housing.
I replaced them with a pair of this type, available from many sellers, link . These produce about 10 times the light (a much whiter light too) and are much better. I was so impressed that I have fitted an additional side-facing one on each side of the roofrack, as well as the rear pair.
Fantastic amount of light, ideal off road, or towing a trailer in narrow dark places!
Post #448113 21st Aug 2015 6:54pm
Crafty1980
I'm looking to install a pair of scenelites now that I've saved a bit of dosh!
Was trying to look at the wiring diagrams that someone put up early in this thread but they're not there anymore.
Could anyone help me out with this? I'd like them to automatically work when selecting reverse gear, but also would like a switch in the back to operate from a permenant live.
I know the purple wire in the rear interior light is a permenant live... Is that the most sensible one to aim for? ...or are there any others in the very rear that could be used? I know earlier 90s used to have one at the very back but that's gone now hasn't it?!
Thanks,
Ben
Post #470857 8th Nov 2015 11:00pm
Crafty1980
...I forgot to add... What are the legalities with reversing lights? Once I've installed the scenelites, could I do away with the existing reversing light altogether?!?
Post #470858 8th Nov 2015 11:02pm
leeds
Not legal I am afraid to say.
Reversing lights have to be type approved which basically means E marked. I very much doubt that the scene lights are E marked.
Maximum number of reversing lights is two. Position etc no requirements.
Now if you have normal reversing lights plus say two scene lights separately switched as work/camping lights then you could legally use them to reverse up your private drive as you are not on a public highway Whistle .
Brendan
Post #470864 9th Nov 2015 12:01am
Crafty1980
Interesting! Same goes for a big light bar on the front I assume? i.e. You can wore it into the full beam circuit, as long as it's also able to be switched off completely or switched on independently?!
Post #471070 9th Nov 2015 7:21pm
