Home > Puma (Tdci) > Vibration with hard throttle in 6th
Page 1 of 3 123>
holmessato
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
First post for a while. Things have been OK for a fee month. Recently I notice a hard vibration, like driving over rumble strips, from the rear of the drive train when I push on hard in 6th gear from low revs. Only in 6th and only with a fairly hard push of the throttle.
Any ideas? Prop shaft, transfer box, rear diff?
Post #44604 7th Nov 2010 11:25pm
Tim_NZ
Australia
I would say it's your clutch. The anti-rattle springs flog their holes out which causes the shudder.
Cheers,
Tim
Post #44618 8th Nov 2010 8:43am
pom
i get the same thing, still under warranty - does something need replacing ?
Pom
Post #44625 8th Nov 2010 10:35am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Interesting. I get a similar sound if I shift early and let the vehicle pull up to speed. Like a rumble and a bucket of bolts shaking.
Post #44679 8th Nov 2010 7:28pm
AndrewS
Clutch I expect. Or may be the gearbox. Do a bit more investigation. Note the speed and gear you are in when it happens. then report back Thumbs Up 130's have feeling's as well you know Smile
Post #44688 8th Nov 2010 8:18pm
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Why are you pushing hard from low revs in 6th? It's an overdrive gear, so inevitably your going to stuff it up. Change down a gear or two, and then tank it.
Post #44707 9th Nov 2010 8:26am
pom
i can get it to happen every time in top gear, around 50-55, floor it and it shakes, rattles and judders. Flooring it in other gears doesn't have the same effect.
Pom
Post #44769 9th Nov 2010 4:28pm
holmessato
Glad to hear its not just me. Its not the clutch, that was replaced less than 1500 miles ago under warantee and completely solved the previous transmission problem I had (sharp take up and high biting point).
As reported, its only in 6th, and not at unusually low revs. No problems in any other gears or at anything other than near-max throttle position. No unusual sounds from the box in 6th at 'lowr throttle positions. I do have BAS remap, so slightly more power going through the transmission than spec, but I dare say it will still happen if I reverted to standard tune (will try at the weekend). It sounds like something is starting to resonate given the combination of gear and power demand.
Post #44838 9th Nov 2010 11:34pm
LROV90
Australia
I too have the same juddering. I also have the BAS remap and the juddering only happens with the remap running. Thinking it might be the clutch slipping with the extra power??
Try putting the standard file back into the ecu and see if the juddering goes away.
Post #44855 10th Nov 2010 9:07am
holmessato
Sorry, I have been away for a while and yet to try setting the remap back to standard, but the problem is deffinitely getting worse. It needs less throttle now in 6th to provoke the vibration. I have just extended my warantee for another year in expectation of a claim!
I will try going back to standard tune this weekend, but suspect the problem will still be there.
Power train issues are the only problems I have had with the Puma. The TD5 power train of my previous Defender seemed much tighter with mush less back lash. Its a shame since just about every other area of the vehicle is so much better than the TD5.
Post #48450 13th Dec 2010 11:32pm
AndrewS
Build quality on the Puma drive train components is atrocious. The poor quality and failures seemed to happen not long after the Ford takeover. I suspect that Ford forced the suppliers prices down which resulted in poor build or imported cheap replicas of the components.
The best fix would be a TDV8 with auto box and transfer case, Followed by aftermarket props, diffs, drive shafts etc etc 130's have feeling's as well you know Smile
Post #48454 14th Dec 2010 2:59am
MK
MT-82 gearbox it will be std equipment in 2011 Mustangs. I believe the whole problem resides on the clutch. However, I do not see a mustang driver dealing with a dodgy 2nd gear.
I was adviced to fit an older Dodge Dart/Ford Falcon disc.
What is your dealer saying about your nth clutch? Puma 110" SW
Post #48459 14th Dec 2010 9:03am
Big Hop
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Orkney Grey
Hi All
I am new to the defender2 forum, so firstly hello and congratulations on a really good site.
I am also new to the Defender world having just recently purchased my 1st Defender, which is a 2011 110 DCPU, its one of the last 2.4 Puma engined ones in orkney.
I have been searching the forum in regard to this exact problem, which is a very bad vibration in 6th gear when accelerating.
Mine too has been remapped but by Charlie at Twisted and it too suffers with very bad vibrations between 1500 and 2000 rpm - only in 6th gear! There is no vibrations at all over 2000 rpm
Did anyone who was involved originally in this topic actually come up with an answer or find a solution as my dealer has drawn a blank!
Apart from that i am very happy with it Smile
Post #105460 7th Dec 2011 10:11pm
MK
Probably the front propshaft lost its balance Puma 110" SW
Post #105474 8th Dec 2011 12:08am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
It's just started on mine too... In 6th, any hard acceleration (??) around 50mph and I get a juddering, the strange thing is, it only happens in a relatively small rev range, say from 1800 - 2200rpm.. And 1st - 5th are fine.. WEIRD!
Mine's due to go in for a service soon, so I'll have the service chappies have a mooch.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #105493 8th Dec 2011 9:39am
Page 1 of 3 123>
