Home > My Defender > What Did You Do In Your Defender Today |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
I was taken to the landrover show in Malvern for Father's Day, spent loads on the kids and treated my other baby to a nice set of black boost alloys brand new for £250 for the five on a show offer that was to good to miss.
21st Jun 2015 6:47pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Drained and refilled both axles with fresh oil and once i have sorted the H/Brake shoes and oil seal out i will refill the trannybox aswell Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
21st Jun 2015 7:21pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
changed the engine oil and filter, fuel and air filter, all good an no leaks. DEFENDER 90 TDCI XS,
21st Jun 2015 7:24pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Took the caravan to Beith for a service before the summer holidays. It's the first time I have tried the motor with a decent load on it (apart from lugging the wife's purse around 👍) and I was very happy with it. It towed very well, nice and stable with a wee bit of pitching which you'd expect from a SWB motor.
Click image to enlarge |
21st Jun 2015 9:10pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1842 |
Took the Sankey down a mates to be painted
[URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
23rd Jun 2015 7:56am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
23rd Jun 2015 8:04am |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Click image to enlarge Must be trailer day today ..off for a two night camp in Dorset at the weekend so trailer mounted and checked . |
23rd Jun 2015 10:31am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
Fitted back on my recently painted headlight surrounds, lots of work to get them so glossy as they had orange peel effect.
Waxed with Meguiar's #26 Click image to enlarge |
23rd Jun 2015 5:43pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Ordered Blindos. Rock and roll.
24th Jun 2015 9:22pm |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
Fitted new head unit and mic for Bluetooth.
24th Jun 2015 9:55pm |
Another one of those testing moments of Land Rover ownership this morning Off on the school run and a couple of miles in I got the power loss, belching black smoke and the feeling it was running on about 3 cylinders not the 5 it left the factory with on a slight incline, much worse when it turned into a hill. Stopped in a safe gateway and did a couple of stop, let it sit for a minute or two and restarted. That was a short term fix, approached the next hill and another stop/start session plus a fuel pump purge. That got me up the next two hills, just, got the boy to school after smoking out a few of the other mums on the school run, then I set about pulling the fuel pump out parked outside the school.
Not a lot of evidence of the dreaded diesel bug on the primary gauze on the bottom of the pump but by sloshing the pump up and down in the tank it must have disloged whatever the problem was inside the pump. It would have probably only taken 20 minutes with emptying the "carefully selected objects" in the rear that were in the way but as per usual a Land Rover in distress usually brings out other owners to have a chat, probably in sympathy. All done and dusted and gave it a bit of a workout on the way home and all is good again. There's never any rhyme or reason to when I get caught with this, it can do it with a full tank, an allmost empty one and like today a half full tank. One of these days I will have to thoroughly empty and clean the tank, another one of those things on the "todoit" list |
25th Jun 2015 9:17am |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 |
Did the tank last weekend, it took about 3hours to remove the towbar bolts and drop/clean it. It was really clogged with bug so worth doing. I snapped a fuel connector and then had to spend a small fortune on a new fuel lone Also its seriously messy, dust everywhere and diesel spillage. That's why I chose to do it on my parents driveway (it was getting steam cleaned this week anyway). At least I now know its good and performance is way better.
Today I fitted the nanocom in between bouts of dehli belly |
26th Jun 2015 6:05pm |
Made an internal rod rack for carrying loose sea rods ( not in a case or bag ) for when going sea fishing Graham
26th Jun 2015 6:53pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Did my first bit of work on my first LR, replaced all the door bolts with stainless steel ones
26th Jun 2015 7:20pm |
