Home > Puma (Tdci) > Just to be aware: LTB00177 |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Mine was already had this problem 4 month ago....
Technical Service Bulletin No.LTB00177 09 October 2008 Subject/Concern: Brake Vacuum Pump Seal Oil Leak Models: Defender (LD) 2.4L Diesel Only 2.4L Diesel Only VIN-range: 7A732615 Onwards Markets: All Section: 206-07 Summary: Oil leaking from the brake vacuum pump front oil seal. Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31. Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)). Parts Required: Description Part Number Quantity Brake vacuum pump LR012183 1 Gasket LR004381 1 Labour Time: Operation Description Operation No. Time Install a new brake vacuum pump 70.15.19 0.7 hours Repair/Claim Coding: Causal Part: LR012183 ACES Condition Code: 42 Defect Code: Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
22nd Oct 2008 3:29pm |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 |
Happened to me aswell, got it towed and they installed a new one but dont know if its the improved one
Ah well atm its still going good Verdone |
23rd Oct 2008 5:49pm |
I just ask my dealer if they put the modified one or not.
No answer yet.... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
23rd Oct 2008 6:51pm |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 |
In South Africa most if not all Puma TDCi Defenders have had this problem due to the hot dusty conditions as far as I understand. Most have been replaced with the old unit, I think the new unit was only released this month , mine has the old unit so I expect it will start leaking and need replacement soon(with the new unit this time ), my old one started leaking at about 16 000km and was replaced at 20 000km.
25th Oct 2008 9:33am |
Thanks Fontuin
Just I receive the answer from the dealer: Was replaced for the old one. New one was on the market from Sept. So, we are waiting to have the same trouble again Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th Oct 2008 1:29am |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
This makes me b y mad................Transits have suffered from this problem long before Ford put the engine in the Defender and they still havn't sorted it.............Sorry I think that is unacceptable......hope you chaps don't have probs
26th Oct 2008 7:17pm |
I was wondering about whether this was the case, the problem with the Transit was/is probably not as severe because it would not be used in hot dusty condtions to the same extent that Defenders are (we don't even have transits here in SA).
Not a question of if, it is a question of when, the old pump will start leaking at some stage in the conditions I use my vehicle in. |
27th Oct 2008 6:46am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
I'm on my 5th Nothing to do with dust. In my opinion. Its the location of the pulley and the tension on the belt. The belt does not ride over the little pulley it actually goes round the pulley. If that makes sense Causing it to be pulled down. They should fit and idler pulley next to the vac pulley to reduce the stress.
I had a new one (new type) replace 4-5 days before going to Morocco it failed within 2000 miles. I was not allowed to take a spare as they are in limited supply and Land Rover said that one has been allocated to my car already so tough. Luckily for me the support vehicle had 2 spares. Also Nick at Yeovil Land Rover was on stand buy to ship one out for me |
4th Nov 2008 9:22am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I am thinking of (if I ever get mine back ) buying a spare for next years trip. Is it easy to fit? |
4th Nov 2008 9:32am |
Mine just failed, engine is covered with spatters of oil again ffs
Verdone |
8th Nov 2008 11:07am |
[quote="The Boy"]
Yes |
8th Nov 2008 6:35pm |
I got it back with no new vacuum pump , they cant get the new ones and they cant get the old ones anymore, so now i have to wait maybe more then a month
Anyone know whats going on???? U pay plenty of money, i dont care if it rains inside or all that but i do expect to it to be mechanically in a good state no?? |
4th Dec 2008 4:48pm |
WHAT?
If I understand yours will be out of service for one month? That's not good... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
4th Dec 2008 5:48pm |
No they gave it back since its not that severe yet, since ive had the problem once i checked regurly and saw it was beginning to leak again
So i took it in to the dealers and after a week i got it back with done what i asked except the vaccum pump since all the old ones r recalled and their are no new ones!!!????!!!! I wonder if anyone can check that cause i hate driving with oil spilling around Verdone |
4th Dec 2008 7:04pm |
