Home > Puma (Tdci) > Just to be aware: LTB00177
Eduardo
Mine was already had this problem 4 month ago....
Technical Service Bulletin
No.LTB00177
09 October 2008
Subject/Concern: Brake Vacuum Pump Seal Oil Leak
Models:
Defender (LD) 2.4L Diesel Only
2.4L Diesel Only VIN-range: 7A732615 Onwards
Markets: All
Section: 206-07
Summary:
Oil leaking from the brake vacuum pump front oil seal.
Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31.
Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)).
Parts Required:
Description Part Number Quantity
Brake vacuum pump LR012183 1
Gasket LR004381 1
Labour Time:
Operation Description Operation No. Time
Install a new brake vacuum pump 70.15.19 0.7 hours
Repair/Claim Coding:
Causal Part: LR012183
ACES Condition Code: 42
Defect Code: Eduardo
Post #4297 22nd Oct 2008 3:29pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
This happend to mine two days after getting back from the Italian Alps. Drop nearly half the oil in 2 miles.
Post #4299 23rd Oct 2008 2:38pm
Verdone
Belgium 2007 Defender 90 Puma 2.4 HT Java Black
Happened to me aswell, got it towed and they installed a new one but dont know if its the improved one Laughing
Ah well atm its still going good Cool
Verdone
Post #4300 23rd Oct 2008 5:49pm
Eduardo
I just ask my dealer if they put the modified one or not.
No answer yet.... Eduardo
Post #4301 23rd Oct 2008 6:51pm
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
In South Africa most if not all Puma TDCi Defenders have had this problem due to the hot dusty conditions as far as I understand. Most have been replaced with the old unit, I think the new unit was only released this month Question , mine has the old unit so I expect it will start leaking and need replacement soon(with the new unit this time Mr. Green ), my old one started leaking at about 16 000km and was replaced at 20 000km.
Post #4314 25th Oct 2008 9:33am
Eduardo
Thanks Fontuin
Just I receive the answer from the dealer: Was replaced for the old one. New one was on the market from Sept.
So, we are waiting to have the same trouble again Sad Sad
Cheers! Eduardo
Post #4321 26th Oct 2008 1:29am
Fatboy Slim
Wales
This makes me b Censored y mad................Transits have suffered from this problem long before Ford put the engine in the Defender and they still havn't sorted it.............Sorry I think that is unacceptable......hope you chaps don't have probs Confused
Post #4327 26th Oct 2008 7:17pm
Fontuin
I was wondering about whether this was the case, the problem with the Transit was/is probably not as severe because it would not be used in hot dusty condtions to the same extent that Defenders are (we don't even have transits here in SA).
Not a question of if, it is a question of when, the old pump will start leaking at some stage in the conditions I use my vehicle in.
Post #4331 27th Oct 2008 6:46am
AndrewS
I'm on my 5th Big Cry Nothing to do with dust. In my opinion. Its the location of the pulley and the tension on the belt. The belt does not ride over the little pulley it actually goes round the pulley. If that makes sense Embarassed Causing it to be pulled down. They should fit and idler pulley next to the vac pulley to reduce the stress.
I had a new one (new type) replace 4-5 days before going to Morocco it failed within 2000 miles. I was not allowed to take a spare as they are in limited supply and Land Rover said that one has been allocated to my car already so tough. Luckily for me the support vehicle had 2 spares. Also Nick at Yeovil Land Rover was on stand buy to ship one out for me
Post #4470 4th Nov 2008 9:22am
The Boy
I am thinking of (if I ever get mine back ) buying a spare for next years trip. Is it easy to fit?
Post #4473 4th Nov 2008 9:32am
Verdone
Mine just failed, engine is covered with spatters of oil again ffs Evil or Very Mad
Verdone
Post #4558 8th Nov 2008 11:07am
AndrewS
[quote="The Boy"]
AndrewS wrote:
Is it easy to fit?
Yes Thumbs Up
Post #4573 8th Nov 2008 6:35pm
Verdone
I got it back with no new vacuum pump Shocked , they cant get the new ones and they cant get the old ones anymore, so now i have to wait maybe more then a month Neutral
Anyone know whats going on????
U pay plenty of money, i dont care if it rains inside or all that but i do expect to it to be mechanically in a good state no??
Post #5266 4th Dec 2008 4:48pm
Eduardo
WHAT?
If I understand yours will be out of service for one month?
That's not good... Eduardo
Post #5267 4th Dec 2008 5:48pm
Verdone
No they gave it back since its not that severe yet, since ive had the problem once i checked regurly and saw it was beginning to leak again Big Cry
So i took it in to the dealers and after a week i got it back with done what i asked except the vaccum pump since all the old ones r recalled and their are no new ones!!!????!!!!
I wonder if anyone can check that cause i hate driving with oil spilling around Big Cry
Verdone
Post #5271 4th Dec 2008 7:04pm
