Home > In Car Electronics > The definitive Defender ICE thread
Page 53 of 69 <123 ... 525354 ... 676869>
AlexPuma42
not long ago fitted a Kenwood Active Sub into the defender - This accompanied with the upgraded speakers under the dash has vastly improved the sound quality but I still seem to be missing the mids and my tiny speakers at the front are now suffering! I have just been given a set of 6x9's which will be fitted in due time and a good friend who is a joiner has said he will make a box for them to hang from the roof behind the seats! I am still playing with the idea of fitting some spare speakers i had out of a car in the rear but feel these will be wasted as it is a van and when covered up i will struggle to hear them! I will try and get some photos of the sub in the mean time! 110 Hard Top - Izmir Blue
Post #372436 18th Nov 2014 10:16am
Make sure if they are boxed that the box internal volume is correct for the speaker.
These details should be on the speaker boxes / booklets.
Usually in cubic ft / litres, I usually go by cubic ft.
Various calculators online to work this out, and you should try to go for the largest size recommended by manufacturer.
Obviously fitting location and practicality can be an issue.
Thumbs Up
Post #372438 18th Nov 2014 10:25am
AlexPuma42
cheers steve completely missed this and will need to work it out cheers for pointing out!
These are the 6x9's I've been given did a quick google search on the product code as i don't have a book/box
http://www.caraudiocentre.co.uk/product_m-...-21412.htm
iv also added a photo of the Active sub fitted - It needs tidying up but i put it in in a rush ready for a long distance journey!
Post #372451 18th Nov 2014 11:37am
Have you managed to do any more work on the above at all yet?
Post #378293 11th Dec 2014 11:20pm
AlexPuma42
No not yet mate although iv now got all the ply and insulation to re-board the back after that I will get the box built into it so on the to do list for the new year 110 Hard Top - Izmir Blue
Post #381244 23rd Dec 2014 9:31am
Sounds good. Thumbs Up
Post #381275 23rd Dec 2014 12:30pm
ZeDefender
You won't regret the Kenwood sub Thumbs Up
I believe it's the successor to the one under the wife's seat. I own both and can confirm they are both excellent Bow down
As far as mid-range goes, I have the sub in the Defender covering its full range (not just thumping) and the sound is great. Tell someone you love them today because life is short.
Post #381287 23rd Dec 2014 1:13pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Steve et all,
Quick question! I think!
My install which I hope to complete in a few weeks if I can get 5 minutes to myself from my kids!
NAK head unit which has 2 sets of pre outs and 1 Sub woofer pre out.
Up front the normal Focal 100 KRS and tweeters in the stock position .
Then I have a set of Focal 165 KP and tweeter behind the rear seat but in front of the rear passengers which I want to make customised fibre glass pods.
I was then going to customise my cubby box to sit a 8 inch sub on the rear of it with separate dedicated sub amp.
Power - from a genesis profile 4 amp which will sit under the cubby box which I intend to raise slightly anyway so its the correct height.
I appear to have a spare set of Focal 100 KRS now as I bought a second hand set which didn't have the tweeter housing thinking I could easily get a new tweeter housing, I was wrong they are actually quite hard to get. So I ordered a new set.
Anyways as I have a spare set I was wondering about a 6 speaker set up.
ie putting the spare 100 KRS in the stock position at the back?
I may be wrong but this would need either 3 amps ie 2 normal and 1 dedicated subwoofer or 2 amps 1 being bridged taking a set of speakers and sub.
but this has given me a problem with the number of pre-out puts from the HU any thoughts or suggestions
Hope this makes some sense
Post #431072 15th Jun 2015 1:40pm
barbel jim
You could just wire the 100 KRS in together, ok you wont have the fader function, but as infil and being matching size/model they will play the same anyway Thumbs Up
Post #431118 15th Jun 2015 6:54pm
barbel jim
Out of interest what sub are you thinking about ??? I looking at doing the same with my new one. Transfering the old double 10" box will take up too much room in the back, now I need seats Big Cry Going to struggle to get a 10" in the cubby. I like the JL 8W7 AE-3, but a tad expensive and maybe a bit OTT ! I've herd the 8W3v-4 in the dedicated JL box, but does struggle a bit with the real lows. I am considering the Alpine SWR 8D2, but the required enclosure is a bit big, and details a bit vague
Post #431130 15th Jun 2015 7:12pm
You could either use an RCA splitter or look into the specs of your Amps as to if the have pre-outs in and out or just in.
If they have both like mine does you can 'daisy' chain them which would keep things more simple to set up. (And control)
Have a look here: http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
You are probably best with a dedicated output for your Sub Amp and maybe link or split the other feeds instead as you want good control of the bass.
If you do make some fibreglass pods be sure to put a photo up here it'd be great to see, think they'd need to be fairly heavyweight / well constructed in the Defender to be effective but depends on fitting location of course.
Post #431132 15th Jun 2015 7:12pm
Jim - A 10" is possib,e when I looked into the enclosure specs enforce but the cubby would need to be custom built and bet made pretty much as wide as you can fit and longer too.
That'd leave you with top or front face as mounting options only.
I stuck to an 8" as it just looks right and the cubby is only a touch larger. (Longer I hade mine a touch only.)
I've found it much better since Dynamat fitted underneath.
You need good fixings as it's only an acess plate underneat that dissipates the bass rather than into the body.
Post #431137 15th Jun 2015 7:17pm
barbel jim
Steve Told you to Dynamat Mr. Green Think going 10" will make the cubbuy too oversized, and it wont look stock/stealth !
On a separate note though be fitting some 5" focals in the front of the new 90 this weekend !! We'll soon find out if they fit Whistle !!!
Post #431165 15th Jun 2015 8:02pm
Don't forget photos Jim!
Post #431169 15th Jun 2015 8:06pm
barbel jim
Its been a painful week Steve Stock LR speakers are PANTS, Even with dynamat Banging Head Banging Head
Post #431170 15th Jun 2015 8:12pm
