Home > Maintenance & Modifications > fitting ARB Air lockers for Puma
Page 2 of 4 <1234>
AndrewS
That's what I was trying to say Whistle it was difficult at the time I posted that, sat in the passenger seat of J-Lo belting round the M25 130's have feeling's as well you know Smile
Post #42629 13th Oct 2010 7:45pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
So in answer to the earlier question, I specifically bought a truck with no TC, when I fit the front lockers it will be with Ashcroft HD halfshafts and CV joints. I'll probably use the front locker once in a blue moon but at least I'll know that I can lock the whole drivetrain should I wish.
Post #42668 14th Oct 2010 6:18pm
BigMike
Surely though if you remove the relay for the TC (or fit a switch to turn it off/on), fit a rear locker only, then you're all set? What would be the issue with that set up?
What I dont understand is why you would need to engage your (normal) difflock in the set up above, since your rears would be turning at the same speed anyway, and those rears would maintain your momentum even if one front was spinning?
another question - if you fit front and rear lockers, then surely you dont need to mess around with the TC at all in terms of removing the relay or turning your off switch because the wheels would constantly turn anyway?
oh and why would you want to be turning corners if you did have both front and rear air lockers engaged?
Post #43000 18th Oct 2010 11:29pm
Naks
If you don't lock your CDL, the rear axle will not get any drive if any of the front wheels lose traction Wink
Post #43021 19th Oct 2010 8:35am
jst
^^^ what he said. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #43025 19th Oct 2010 9:18am
BigMike
Gotcha.
So why not just have a rear locker and forget doing the front? Would that create any issues with the TC system?
Post #43026 19th Oct 2010 9:25am
Naks
Apparently if you lock the CDL & RDL and still have TC, the front driveshafts take a pounding and may snap when you lose traction on the front wheels.
Post #43027 19th Oct 2010 9:29am
BigMike
I just had an email from Dave Ashcroft at Ashcroft Transmissions, and he says that if you have a rear locker only there is no issue re traction control at all.
Post #43298 22nd Oct 2010 4:11pm
BigMike
and another email from the head of technical at ARB in the States who says the same thing...
Post #43304 22nd Oct 2010 5:41pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Trust me it will break bits with TC and a rear locker Thumbs Up how can the Yank comment? They don't have Defenders with TC over there Thumbs Up before you ask how I know, it broke my front diff in the bottom of Morocco this August.
Post #43321 22nd Oct 2010 8:50pm
BigMike
Well, "the Yank" as you so graciously put it happens to be the head of the technical side of ARB, and since ARB lockers are not just fitted to Landrovers, but to many other vehicles both with traction control and without, I'm sure he knows a fair amount about it. I'd have also thought that the owner of Ashcroft transmissions might just know a thing or two about it. Is it at all possible that you broke whatever it was you broke using too much gas, doing something daft, or something you just should not have been doing?
Post #43325 22nd Oct 2010 9:01pm
Sonic3d
Just trying to help Rolling Eyes learn the hard way then
Post #43326 22nd Oct 2010 9:03pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Personally speaking, if both Andrew and Matt say not to do something in a Defender then I'll bow to their experience and not do it. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #43331 22nd Oct 2010 9:49pm
BigMike
Happy to listen and take advice, but when the guys who make and fit these things are saying something different, what do you do?
Post #43359 23rd Oct 2010 8:36am
leeds
How quickly does TC work?
If a wheel just has daylight under it, wheel spins, tyre hits ground. Does TC work that fast on first application to completely stop all wheel spin?
Not talking about having 6' of daylight under tyre.
If you have good grippy tyres and grippy ground, I could imagine a vehicle with TC breaking half shafts/diffs if you become slightly air borne as TC might not have time to respond quickly enough.
TC on our D2 does appear to have a time lag.
So what is the response time given for TC on Pumas?
Brendan
Post #43363 23rd Oct 2010 9:01am
Page 2 of 4 <1234>
