Home > Puma (Tdci) > Blue smoke on start up....
Page 3 of 4 <1234>
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Hi Ian,
Had a spanner on the top at fuel in pipe bit with a tommy bar on the other end of the spanner which got it to rotate side to side but it wouldn't lift.
It needed more leverage to lift it up .... Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #424445 18th May 2015 2:48pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
They can be tricky, as there is nothing to lever on.
Everything is plastic and doesn't take much to crack......how do I know that Whistle
Just keep going side to side, like I say they do pop up eventually Wink
If not, might be time for the slide hammer.... 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #424450 18th May 2015 3:08pm
dgardel
Italy
ian series 1 wrote:
You will find these injectors will either just pull out, or they have stuck solid!
Get a spanner around the 2 flats and give it a wiggle from side to side.
You need to show them who is boss but they will come out.
If not, get a good pair of grips on them and try to pull as your turning it.
It will come out in the end! Thumbs Up
1. new screws
2. put on the thread a little bit of anti friction paste (such as Chesterton 787)
3. tight at 6Nm
4. wait 15 minutes
5. close with protractor further 180� (180 degree rotation)
6. run the engine at idle for five minutes to allow time to the copper seal to adapt well to the head Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #424454 18th May 2015 3:15pm
ian series 1
360 degrees IMHO may be a tad too much? 80" 80" 86" 88" 90"
Post #424460 18th May 2015 3:48pm
dgardel
Italy
My bad 180�
From the manual pag 500.....
http://1drv.ms/1QXFk5p Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #424525 18th May 2015 7:24pm
martinfiattech
If I read this correctly, your number four injector is seized / stuck in the cylinder head.
You could try the slightly naughty workshop removal method. Loosen the injector mounting bolt SLIGHTLY. Say one turn.
Pop off the upper seals or have them slightly resting in there housing on the rocker cover.
Start the engine and see if compression pressure will push the injector up. If it starts chuffing, it should come free.
Granted both injectors will need new seals afterwards.
All the best. Excuse the spelling I`am better with spanners and wires.
Post #424584 18th May 2015 9:05pm
dgardel
Italy
or using an injector removal tool
http://www.ebay.it/itm/111230631885?ssPage...1438.l2649 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #424595 18th May 2015 9:25pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I have the same issue at the moment and have bought all new seals and just need to get round to doing the job. I've also bought an injector seat cutting kit to clean off any soot.
Should I be worried about any crap falling into the cylinders when cleaning up the seats with the cutter?
(kit was something like this http://www.sealey.co.uk/PLPageBuilder.asp?...ctid=13996) 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #424615 18th May 2015 10:03pm
jonesie
Thanks for those replies everyone.
The bolt setting is also on page 434. (Been reading it all evening, wife got cross because I haven't spoke a word for three hours... Rolling with laughter )
Dgardel do those sliders work on the puma? I am paranoid about cracking the rocker cover and they ain't cheap, might be able to hire a set.
Like the idea of using pressure to push it out though.
Also have seen a few adverts for mobile injector removal companies, but by the time I have paid them it might be cheaper to buy the tool.
Jones the quiet one. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424620 18th May 2015 10:10pm
munch90
Cleaned plenty of injector seats and never had a problem
most/all cutters have a pilot spindle on the bottom ( to help keep cutter square to seat ) , this also block the injector hole
just to be on safe side , put a small amount of grease on the cutter to help hold any crap to cutter
you only need to clean carbon of the seat not cut the seat really
Post #424623 18th May 2015 10:15pm
carrotbay
thanks .. I'll sort this once I finish my clutch at the weekend Rolling Eyes 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #424625 18th May 2015 10:22pm
jonesie
Carrotbay we rigged up an oil drain pump as a hoover,( taped a small bore hose to the end of the suction hose, I pumped while the mechanic (nev) hoovered the crap out) it worked really well and only took about 30 seconds per bore to clean them out.
If they are not seized the injectors just pull out.
The top rubber seals once the injector is out just lever out with a flat blade, cleaned the injectors with a bit of scotch brite, as Ian said be careful of the o rings on the fuel pipes and mark/store the injectors in order.
Fired up after about 6 sessions of turning it over for about 20 seconds.
Good luck and did you buy Gen washers? Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424629 18th May 2015 10:29pm
carrotbay
Sounds like a good idea .. yes, genuine washers and new bolts 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #424645 18th May 2015 11:05pm
jonesie
Your a rich man I sent mine back and bought some off ebay at �5 for 4 just couldn't justify nearly �70 for four small washers and they seemed quite hard compared to the ebay ones.
Good luck. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #424647 18th May 2015 11:16pm
carrotbay
Censored .. I've had them too long to send back now .. Set of 4 transit ones on eBay for �5.50 Big Cry 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #424653 18th May 2015 11:29pm
Page 3 of 4 <1234>
