Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 19 of 81 <123 ... 181920 ... 798081>
mk1collector
Ok, so I got asked a couple of pages back to take pics when I replaced the second row triangle sections so here goes. First remove the sill which Is held on by 6, 10mm nuts and bolts from underneath. You can see the brackets where the bolts go on this pic of the back of the sill. Also there are two clips (one front and one back) where the wheel arches attach to the sill, the centre of the clip needs tapping through then the body will come out.
Next drill out the six rivets from the triangle panel and take out the two clips (as above) that hold the wheel arch to the panel.
The panel should then be removable with a bit of wiggling and you should be left with this.
I chose to dinitrol the back of my new panel and left an untreated line where the rivets attach the panel to the car so I could also seal it (belt and braces Rolling with laughter )
 Ray
My build thread
Post #418252 22nd Apr 2015 8:48pm
Tiger
Remember those rivets are unpainted from the factory Thumbs Up
Post #418258 22nd Apr 2015 9:04pm
Tiger
And in the 1st photo I think I'd be letting a doctor or at least a good vet have a look at that arm Shocked
Post #418260 22nd Apr 2015 9:06pm
mk1collector
I also decided to dinitrol under where the panel attaches then added the sealer to the car side. Note there are two washers that need fitting to the bottom two rivet holes in between the panel and the car (I used sealer to stick them on so they didn't move while fitting the panel, don't forget to put the washers in!!!
When you put the new panel in place you need to drill the top two holes for rivets as they don't come on the new panel, make sure your door gap lines up before popping the rivets, then start riveting taking care not to scratch your fresh paint.
Two more holes need drilling in your new panel to put the clips in to hold the wheel arch on (again the holes are not there on genuine panels when supplied) then re-bolt the sill back on (preferably with a friend to help) making sure the sill lines up with surrounding panels. No pics of this bit yet as I'm re-painting my chequer plate before it goes back on. While the sill is off its a good time to dinitrol the inner sill and back of the outer sill while everything is easily accessible. Like this Mr. Green
Hope this helps anyone thinking of doing the job. It's not too difficult but leave a couple of hours to fit each side and get the panel painted before it goes on (front and back) if you want it to last Thumbs Up Ray
My build thread
Post #418261 22nd Apr 2015 9:06pm
mk1collector
Rolling with laughter the rivets have been left unpainted but I did lacquer them so hopefully no more white streaks down the panel Mr. Green Ray
My build thread
Post #418262 22nd Apr 2015 9:08pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Thumbs Up Just the job Ray, this will be very handy when I come to do the ones on my old mans double cab. Do you think it'll be worth cleaning and dinitroling around the outriggers and fitting something like the Gwyn Lewis outrigger mud shields to help curb this in the future too?
Post #418265 22nd Apr 2015 9:28pm
Anderzander
Great job !
Post #418268 22nd Apr 2015 9:37pm
mk1collector
I did clean and treat any surface rust I could find then dinitrolled while it was off. I think the reason the panels bubble there is just the usual Landrover lack of paint to the back of the panel so before fitting I had the panels blasted, zinc coated, powder coated then painted all round and as above dinitrolled and sealed at the back so I'm hoping it won't happen again. As for adding mud shield my chassis and out riggers all seem in pretty good nick so I'm not sure if this is a big problem area. Ray
My build thread
Post #418272 22nd Apr 2015 9:51pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Good work and interesting thread. Thumbs Up just read it from start to finish.
Post #418277 22nd Apr 2015 11:13pm
mk1collector
Thank you Thumbs Up Ray
My build thread
Post #418278 22nd Apr 2015 11:16pm
mk1collector
The sills are back on and both sides done, just waiting for the chequer plate to dry fully now before fitting. If your wondering I put black sills on because it always annoyed me seeing grey around the sides of the chequer plate Rolling with laughter maybe a little bit ocd.
 Ray
My build thread
Post #418582 24th Apr 2015 8:29am
mk1collector
Next job Mr. Green Ray
My build thread
Post #420173 30th Apr 2015 12:43pm
mk1collector
It Looks more purposeful with them on I think
 Ray
My build thread
Post #420211 30th Apr 2015 4:03pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I have had to look back at page 1 of this thread. You have been very busy adding subtle mods to make your defender have greater presence without looking over the top. I think you have done a great job and it spurrs me on to improve mine.
Personally, I think you should keep the boosts with the spacers. They are hard to beat for style, and must be one of the best standard issue alloys.
Top modding Ray, but what happens when you reach the end of the list, because you must be close? 2002 110 td5
Post #420283 30th Apr 2015 8:25pm
mk1collector
Thank you Thumbs Up it has changed a quite a bit from day one but I still want it to look pretty standard, boosts are great but I think a little under sized on a 110 so maybe 18" boosts but I really like the look of sawtooths. It'll be next year anyway so plenty of time to change my mind yet Rolling with laughter I've got loads more stuff planned all in lists, then smaller lists for each section and smaller lists to be finished before certain dates Laughing and when I've finished everything I've still got three mk1 golfs to finish in the garage and the ongoing house projects so my work is in the 40 year plan area Big Cry Ray
My build thread
Post #420321 30th Apr 2015 10:15pm
