Home > Maintenance & Modifications > Spare wheel lock |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
As long as it works an is not powder coated im in!
27th Mar 2015 1:39am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
will be available in plain stainless steel and powdercoated black. WANTED:
SII or SIII in max 1.5k |
27th Mar 2015 9:35am |
jens_1967 Member Since: 05 Jul 2014 Location: South Posts: 5 |
i am interested too
12th Apr 2015 12:56pm |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 |
Interested,
Pplease advise when available from Brendan - thanks |
12th Apr 2015 2:01pm |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
As a few people have shown an interest, I've taken a few photos of the install. All in all an easy job to do.
Click image to enlarge The template supplied negates the need to do any measuring. Click image to enlarge Holes drilled and a dab of paint added to stop any corrosion. Click image to enlarge Stub all bolted on. This was a test fit. I had to add an extra washer as it was all a bit too tight (5 washers used in total) Click image to enlarge And all fitted up. Click image to enlarge Gap between tyre and wiper blade. Click image to enlarge Overall I'm impressed with the lock. Easy to fit, good looking and pretty cheap. One issue I've got is that although 4 spacer washers was too tight, using 5 washers leaves it all a bit loose. This results in a bit of rattling when you shut the rear door. If you could use the wheel spaces fitted on the studs as standard then this wouldn't be an issue as you could just adjust the wheel spacers to tighten it up. However you'd need a whole load of washers to be able to use them. This will also be an issue when I get a spare to match the 285/75/16s fitted to the other wheels. My plan is to knock up a couple of discs of steel to slide in instead of the washers used to space the lock. All in all a good product just let down by minor design issues. Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
18th Apr 2015 6:22pm |
mikeh Member Since: 05 Feb 2015 Location: South Coast Posts: 28 |
Thanks for that Tom. Need to get round to doing mine
Could you put a foam pad or rubber washer between the disc and wheel to stop the rattle? Mike |
18th Apr 2015 6:46pm |
Cant knock that , looks ok
18th Apr 2015 7:05pm |
Good idea that Mike. If you stuck a foam backing to the disc that should stop it all from rattling around. I'll give that a try if I can find some foam. Tom
19th Apr 2015 1:54pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Will it fit with a swing-away wheel carrier?
Merlin |
20th Apr 2015 7:18pm |
Certainly wouldn't fit on a Safari due to the head attachment.
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Apr 2015 7:56pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1301 |
How's this coming along Peter? |
26th Apr 2015 2:45pm |
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 |
Any news from Peter, or Brendan possibly?
14th May 2015 10:25am |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 284 |
Nakatanenga Lock - Any news from Peter, or Brendan possibly? NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
7th Sep 2015 9:40pm |
Here the pics of the prototype. No drilling required, adjustable = fits all wheels, 3mm stainless steel construction
Click image to enlarge Click image to enlarge WANTED: SII or SIII in max 1.5k |
29th Sep 2015 12:27pm |
