Home > Maintenance & Modifications > Spare wheel lock
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 6 of 9 <123456789>
Agree, punched and folded from the backplate, not very strong. It is a prototype though so this may be addressed on production versions. It would be harder to wrench the padlock off anyway since with most wheels it is likely to be within the 'dish' of the wheel.
I am thinking that a system combining the best featues of each, but slightly different to any proposed sofar, might be the ideal.
Incidentally some time ago I bought a number of very high quality puck type locks on which the rim is chamfered, ie the lock is shaped like a slice out of a cone, which would make it impossible to grip them with a Stilson.
An alternative in this application would be to add a shield, possibly one free to rotate, around the outside of the lock. Maybe include bump key protection too. There are many fairly easy ways to make it much harder for Johnny Villain.
Post #459148 29th Sep 2015 9:59pm
nitram17
leeds wrote:
In my opinion it is stupid to spread information on how to overcome any security device.
That second photograph can be easily overcome.
First photograph what is the shear strength of 8mm bolts? OK multiply by 3
Now I doubt 3' stilsons and 6' of scaffold poles are standard equipment of the opportinist scumbags
Now what is the expression? Layers of security??
Brendan
Are you calling me stupid Brenden?I do take offence at that!Lets just agree to differ ..if you cannot take opinions of others that differs from yours ...well that says a lot about you! !pardon me for saying this but you appear a little self righteous when it comes to security!Its my opinion that the more information out there for owners the better! you obviously dont ..can we leave it at that without the insults !...................i hope your lock sells like hot cakes i really do but i wont be buying one unless they beef up the hasp/flange thingy!
Post #459149 29th Sep 2015 10:06pm
nitram17
Sounds like a plan Blackwolf ....what about a collar/shroud that is welded to the front plate(or the front plate could be one piece pressed with a collar in situ) that the lock drops into so its flush with the collar and with and a cutout to access the lock for the key..anyway i am keen to see the results!
Post #459151 29th Sep 2015 10:20pm
leeds
I did not call you stupid. I said it was stupid to spread information which is helpful to the enemy!
The size of the hasp is dictated by the opening in the standard puck lock. So there is a limit on that without redesigning the puck lock.
As BW says the lock is in the dish of the wheel so it would be difficult to get a Stilston square on to it. Most puck locks have a chamfered outer edge. I wonder what that design feature is for?
At least Nakatanenga is trying to come up with a device which will fit most wheels without having to modify the wheel carrier. However any security device has to be cost effective. There would not be many sales of a £1,000 security device to protect a spare wheel costing £150-£250
Layers of security
1) The humble wheel cover! Now is there a nice shiny alloy with a brand new tyre on or is it a rusty steel rim with a bald tyre on?
2). 'Security'. Nut or nuts
3). Cable or chain with padlock
4). Some 'security' device which covers the wheel nuts
Each layer just slows down the scumbags it is not 100% certain to deter the determined thief. Every layer can be overcome with enough time, the right tool and no worries about noise generated
Now does the scumbag just move on to the next Defender, or do they say sod it, get the trolley jack out and a pile of bricks and steals the other 4 wheels?
Brendan
Post #459155 29th Sep 2015 11:02pm
K9F
Most puck locks I see on the rear of work vans have a thick metal shroud (as mentioned) surrounding it. You can only get stilsons on if you have access obviously! Mind you they may turn up with liquid oxygen the appropriate IPE and a hammer?
Rolling with laughter
Anything is better than nothing and the layered approach is best. IMO spare wheels being stolen is a 'minority issue in the overall scheme of protecting your pride and joy, but one I got round to after everything else. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #459174 30th Sep 2015 7:04am
leeds
Why worry about the spare wheel?
I would think that owner would have been 'happier' if just his spare wheel had been stolen. Or less unhappy.
Mal, if you want something more effective then liquid oxygen, try liquid nitrogen or even better some liquid helium which is getting close to absolute zero. Maybe I should go and see my ex work colleagues? Whistle Whistle
How about some hydraulic cutters readily available at your local fire station?
I would imagine most spare wheels are stolen by opportunist thieves who want a quick getaway rather then the determined scumbag who comes tooled up with every means to overcome security devices. The biggest problem with stealing wheels is just jacking up the vehicle!
Brendan
Post #459186 30th Sep 2015 8:05am
K9F
Agree, no point worrying about the spare if the whole truck's gone!
Scenario....... Hypothetically if a spare wheel lock costs ballpark the same amount as a recommended and well-supported tracker unit and you have neither which should take priority? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #459188 30th Sep 2015 8:26am
nakatanenga
Germany
OMG!
The pictures show a thin sheet metal prototype! The mass production will be 3mm stainless with a collar around the lock.
Wheels are kind a "deep dish" so it is not that easy to grab the lock etc WANTED:
SII or SIII in max 1.5k
Post #459199 30th Sep 2015 9:09am
Venomator
Is it possible to see something of a more refined 'Prototype then please Peter... Whistle
Thanks... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #459256 30th Sep 2015 1:16pm
nakatanenga
Germany
Keep calm and wait please.... WANTED:
Post #459266 30th Sep 2015 1:44pm
Venomator
Man with whetted appetite does not remain calm for long... Whistle
And my build progresses at an unstoppable pace... Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #459267 30th Sep 2015 1:47pm
RRUK
If we could all live with a rubbish spare wheel just for emergencies then no one would care, including aforementioned scumbags! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #459313 30th Sep 2015 4:27pm
nitram17
nakatanenga wrote:
OMG!
Be homest now Peter !was the collar in the original desigh?i will believe you! honest! Whistle
Post #459318 30th Sep 2015 4:41pm
K9F
As Blackwolf correctly stated....
blackwolf wrote:
..... It is a prototype though so this may be addressed on production versions.......
It doesn't really matter if the collar was an afterthought or not! The whole concept of a prototype is that it can be developed and advanced upon. Getting the prototype out there to gauge opinion and see if there are any constructive ideas or feedback for the final version is the way to go! Glad to hear it will have a collar on, undoubtedly this addition will increase the attractiveness for those that may wish to purchase one, deter the thieves further and make those that may wish to pour scorn on the idea have to search a damn sight longer and harder on the internet to defeat it.
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #459319 30th Sep 2015 4:51pm
nitram17
Are you getting at me k9?Im a simple fella and i came upon the original post by Peter and thought it was an interestihg idea........i had never heard of a puck lock so i put puck lock into google and got the video i posted at the top of the list and i thought other defender owners would be interested! THen having seen the video it appeared to me that the flange of hasp om the lock was a week point ....then brenden jumped in infering i was stupid to post the video and peter posts omg and there will now be a shroud but implying that it was his intention all along to shroud the lock..............I agree with you that it doesnt matter whether the collar was an afterthought but if i had designed something put it out for view on a public forum i would willingly acknowledge the contribution of others to the final design ....peter is obviously not that sort of bloke and good luck to him!
Post #459331 30th Sep 2015 5:47pm
This topic is locked: you cannot edit posts or make replies.  Back to top
