Home > Puma (Tdci) > rear diif flange bolt loose AGAIN
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Loose rear diff flange bolt causing 'clunk'.
Had car from new, problem started after 5 years. Tightened it up, happened again after 2 months.
Tried loctite second time, same problem again after 2/3months.
Any ideas anyone??
Grateful for any input
Thanks
David in Tanzania
Post #415436 11th Apr 2015 4:50pm
dailysleaze
Are you tightening it to 100nm?
Post #415521 11th Apr 2015 8:27pm
davidpalfreyman
Yes, as the book says.
Thanks for your response
David
Post #415596 12th Apr 2015 3:46am
LR90XS2011
is there play in the splines? if there is then you will need to remove the play by hopefully just fitting a new drive flange. DEFENDER 90 TDCI XS,
Post #415601 12th Apr 2015 6:43am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
If your getting a clunk when taking up drive your ment to apply a certain loctite, I can't remember which type but I've got some at my workshop which I can check tomorrow, there was also a Land Rover bullitin about it.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #415606 12th Apr 2015 7:54am
martinfiattech
Is your torque wrench still within calibration. If so I would go along with above posts and fit a new bolt too. Excuse the spelling I`am better with spanners and wires.
Post #415676 12th Apr 2015 12:34pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
Search for some Nordlock washers.
They are very effective and I have used them on numerous high vibration applications over the years.
Post #415709 12th Apr 2015 3:20pm
derbywill
I've just checked and the loctite 648 you apply it to the splines on the pinion and it stop any movement between the splines on the pinion.
Regards
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #415936 13th Apr 2015 12:29pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
For peace of mind, you could always try wire-locking the nuts. Idea
Maybe a bit extreme, but it works for aircraft. --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #415940 13th Apr 2015 1:12pm
davidpalfreyman
I applied it only to the bolt threads last time.
I will try it tomorrow.
Thanks so much
David
Post #415941 13th Apr 2015 1:12pm
davidpalfreyman
Thanks for the idea. How do you wire lock the nut?
Keen to know and try it
David
Post #415945 13th Apr 2015 1:30pm
LRmud
Google is your friend! Lots of pics and video. --------------------------------------------------------------------------------------------------
1989 Defender 90
Post #415948 13th Apr 2015 2:08pm
UtilityTruck
Re: rear diif flange bolt loose AGAIN
Any ideas anyone??
Thanks
David in Tanzania
It's probably worth changing the fixings too if they're repeatedly coming loose.
Post #415953 13th Apr 2015 3:25pm
Flyingfocrs
Hate to be picky but lock wire won't stop them coming loose, it is only to prevent them coming all the way out and becoming FOD.
Nordlock washers once torqued are tested to retain torque even under extreme vibration conditions. i have used them for years in various locations and they do not come loose once torqued correctly.
http://www.nord-lock.com/nord-lock/wedge-locking/
Post #416062 14th Apr 2015 1:17am
Roy5695
wire-locking done correctly will stop the things from coming un-done, I've done it many many times as part of my aeronautical engineering, pretty much everything is wirelocked that is critical if came un-done
Post #416064 14th Apr 2015 1:42am
