Home > Puma (Tdci) > rear diif flange bolt loose AGAIN |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
Are you tightening it to 100nm?
11th Apr 2015 8:27pm |
davidpalfreyman Member Since: 06 Oct 2010 Location: tanzania Posts: 67 |
Yes, as the book says.
Thanks for your response David |
12th Apr 2015 3:46am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
is there play in the splines? if there is then you will need to remove the play by hopefully just fitting a new drive flange. DEFENDER 90 TDCI XS,
12th Apr 2015 6:43am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
If your getting a clunk when taking up drive your ment to apply a certain loctite, I can't remember which type but I've got some at my workshop which I can check tomorrow, there was also a Land Rover bullitin about it.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
12th Apr 2015 7:54am |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Is your torque wrench still within calibration. If so I would go along with above posts and fit a new bolt too. Excuse the spelling I`am better with spanners and wires.
12th Apr 2015 12:34pm |
Flyingfocrs Member Since: 12 Jan 2015 Location: Deepest darkest Aberdeenshire Posts: 155 |
Search for some Nordlock washers.
They are very effective and I have used them on numerous high vibration applications over the years. |
12th Apr 2015 3:20pm |
I've just checked and the loctite 648 you apply it to the splines on the pinion and it stop any movement between the splines on the pinion.
13th Apr 2015 12:29pm |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 |
For peace of mind, you could always try wire-locking the nuts.
Maybe a bit extreme, but it works for aircraft. -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
13th Apr 2015 1:12pm |
I applied it only to the bolt threads last time.
I will try it tomorrow. Thanks so much David |
Thanks for the idea. How do you wire lock the nut?
Keen to know and try it David |
13th Apr 2015 1:30pm |
Google is your friend! Lots of pics and video. --------------------------------------------------------------------------------------------------
13th Apr 2015 2:08pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
It's probably worth changing the fixings too if they're repeatedly coming loose. |
13th Apr 2015 3:25pm |
Hate to be picky but lock wire won't stop them coming loose, it is only to prevent them coming all the way out and becoming FOD.
Nordlock washers once torqued are tested to retain torque even under extreme vibration conditions. i have used them for years in various locations and they do not come loose once torqued correctly. http://www.nord-lock.com/nord-lock/wedge-locking/ |
14th Apr 2015 1:17am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
wire-locking done correctly will stop the things from coming un-done, I've done it many many times as part of my aeronautical engineering, pretty much everything is wirelocked that is critical if came un-done
14th Apr 2015 1:42am |
