Home > Technical > Vibration, BUZZ on gear lever. |
Wil, welcome to the site buddy! Look here: http://www.defender2.net/forum/topic2954.html?highlight=rattling Here: http://www.defender2.net/forum/topic3324.html?highlight=rattle Especially here: http://www.defender2.net/forum/topic3656.html?highlight=rattle Possibly here: http://www.defender2.net/forum/topic3335.html?highlight=rattle Hope this all helps! Quite often a few searches will set you on the right track! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Sep 2010 7:57am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
A known problem with LR and it can only be rectified by fitting a new gearstick as i was told the machining on pre 2009 gearsticks was way off tolerance... do not accept a grease fix as it will re-occur. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
26th Sep 2010 9:55am |
landyman1 Member Since: 11 Jul 2009 Location: Pembrokeshire,South Wales Posts: 57 |
Had similar problem showing at about 10,000 miles. Gear stick vibration in 5th and 6th gear around 55 -60mph, originally only under load and after at least half an hour driving. Travelling empty takes nearly an hour to show itself. Fortunate in a way that dealer is nearly two hour drive, agreed to send mechanic out with me immediately on arrival and subsequently changed the gear stick.
This and other minor issues dealt with under warranty without fuss---- replaced mirror arm with paint just beginning to bubble, replaced rear worklight with rust appearing on mesh , couple of door screws and a propshaft to rear diff oil seal.reset steering wheel to 12 oclock, was slightly off at 3 mins to 12. Even washed the vehicle all at no charge. Top marks to LIKES LANDROVER at Brecon ( was told that nearly 50% of their sales are defenders so maybe that's why they seem to know what they are doing) Well chuffed with the service 1981 series 3 swb gone 1986 v8 110 station wagon current 2009 puma 110 xs utility station wagon latest addition |
28th Sep 2010 9:57pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Im on my third and its started again Mike
28th Sep 2010 10:59pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
still the same..... on second and out of warranty o well NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
28th Sep 2010 11:01pm |
Noticed the windscreen hinge that isnt anymore is corroding Mike |
28th Sep 2010 11:02pm |
MSE You really are a nob head :rolllaugh NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
28th Sep 2010 11:09pm |
great to feel the love (not that it was wanted ) Mike |
29th Sep 2010 7:15am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
I noticed that if you could still get a bonnet mount spare wheel that would be rusting too Mike 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
29th Sep 2010 7:29am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Willie, which stealer are you using? I have heard good things about Waterford |
29th Sep 2010 7:34am |
First of i was saying I'm on my second new gearstick and now out of warranty ...looking back at the post it doesn't make much sense that's what happens when your and try to post NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
29th Sep 2010 9:39am |
bhayes Member Since: 13 Sep 2011 Location: Greytown Posts: 4 |
My 2009 Defender 90 Puma gear stick vibration continues, despite THREE new replacement gears sticks. Has any one got an answer has to how to repair this??
Surely by now Land Rover would have had a recall on this or come up with some answer?? |
13th Sep 2011 12:28pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Some fit a grease nipple on top of the gear stick`s knob Puma 110" SW
13th Sep 2011 12:40pm |
A grease nipple on TOP of the gear stick knob?? - confirm through the rubber knob?, and then confirm the grease runs down the length of the gear stick?? - pretty unsightly?
13th Sep 2011 12:56pm |
