Home > Technical > Vibration, BUZZ on gear lever.
wilfranco
South Africa 2007 Defender 90 Td5 SW Alpine White
Good mornibg all.
I have a intermitent "Buzz" on the gear lever ay about 90 Km/h and it then stops at abot 100Km/h
I have had the vehicle at the agents but then ,Murphy's law applies " no Vibration detected during test drive"
on one occassion I went with the service consultant on a test drive and there was no buzz.
Guese what on the way home there was this damn buzz.
I have checked the basics, oil in gearbox, mountings etc etc.
I wonder if any body has had the same experience, and what might the buzz be,
Kind Regards
Willie Wright
Post #41303 26th Sep 2010 7:20am
K9F
lrdxb110 wrote:
My defender gear lever is rattling, particularly when overtaking and at acceleration when shifting from 5 to 6 . In the LR workshop at the moment getting a new gear stick assembly under warranty. Mr. Green
Wil, welcome to the site buddy! Thumbs Up Dog
Look here:
http://www.defender2.net/forum/topic2954.html?highlight=rattling
Here:
http://www.defender2.net/forum/topic3324.html?highlight=rattle
Especially here:
http://www.defender2.net/forum/topic3656.html?highlight=rattle
Possibly here:
http://www.defender2.net/forum/topic3335.html?highlight=rattle
Hope this all helps! Thumbs Up Quite often a few searches will set you on the right track! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41305 26th Sep 2010 7:57am
RED-DOT
A known problem with LR and it can only be rectified by fitting a new gearstick as i was told the machining on pre 2009 gearsticks was way off tolerance... do not accept a grease fix as it will re-occur. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #41314 26th Sep 2010 9:55am
landyman1
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Very Happy Had similar problem showing at about 10,000 miles. Gear stick vibration in 5th and 6th gear around 55 -60mph, originally only under load and after at least half an hour driving. Travelling empty takes nearly an hour to show itself. Fortunate in a way that dealer is nearly two hour drive, agreed to send mechanic out with me immediately on arrival and subsequently changed the gear stick.
This and other minor issues dealt with under warranty without fuss---- replaced mirror arm with paint just beginning to bubble, replaced rear worklight with rust appearing on mesh , couple of door screws and a propshaft to rear diff oil seal.reset steering wheel to 12 oclock, was slightly off at 3 mins to 12.
Even washed the vehicle all at no charge.
Top marks to LIKES LANDROVER at Brecon ( was told that nearly 50% of their sales are defenders so maybe that's why they seem to know what they are doing)
Well chuffed with the service Very Happy 1981 series 3 swb gone
1986 v8 110 station wagon current
2009 puma 110 xs utility station wagon latest addition
Post #41504 28th Sep 2010 9:57pm
mse
Im on my third and its started again Exclamation Big Cry Mike
Post #41507 28th Sep 2010 10:59pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
still the same..... on second and out of warranty o well Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41508 28th Sep 2010 11:01pm
mse
Noticed the windscreen hinge that isnt anymore is corroding Mike
Post #41510 28th Sep 2010 11:02pm
fekete
Rolling with laughter Rolling with laughter MSE You really are a nob head Rolling with laughter Rolling with laughter :rolllaugh NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41512 28th Sep 2010 11:09pm
mse
great to feel the love Thumbs Up (not that it was wanted Rolling with laughter) Ner Ner Mike
Post #41515 29th Sep 2010 7:15am
Grockle
I noticed that if you could still get a bonnet mount spare wheel that would be rusting too Mike Whistle Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #41517 29th Sep 2010 7:29am
Naks
Re: Vibration, BUZZ on gear lever.
wilfranco wrote:
I have had the vehicle at the agents but then ,Murphy's law applies " no Vibration detected during test drive" on one occassion I went with the service consultant on a test drive and there was no buzz.
Willie, which stealer are you using? I have heard good things about Waterford
Post #41519 29th Sep 2010 7:34am
fekete
First of i was saying I'm on my second new gearstick and now out of warranty ...looking back at the post it doesn't make much sense Embarassed Embarassed that's what happens when your Censored and try to post Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41529 29th Sep 2010 9:39am
bhayes
South Africa 2009 Defender 90 Puma 2.4 SW Keswick Green
My 2009 Defender 90 Puma gear stick vibration continues, despite THREE new replacement gears sticks. Has any one got an answer has to how to repair this??
Surely by now Land Rover would have had a recall on this or come up with some answer??
Post #88869 13th Sep 2011 12:28pm
MK
Some fit a grease nipple on top of the gear stick`s knob Shocked Puma 110" SW
Post #88873 13th Sep 2011 12:40pm
bhayes
A grease nipple on TOP of the gear stick knob?? - confirm through the rubber knob?, and then confirm the grease runs down the length of the gear stick?? - pretty unsightly?
Post #88878 13th Sep 2011 12:56pm
