![]() | Home > Technical > Vibration, BUZZ on gear lever. |
Wil, welcome to the site buddy! ![]() ![]() Look here: http://www.defender2.net/forum/topic2954.html?highlight=rattling Here: http://www.defender2.net/forum/topic3324.html?highlight=rattle Especially here: http://www.defender2.net/forum/topic3656.html?highlight=rattle Possibly here: http://www.defender2.net/forum/topic3335.html?highlight=rattle Hope this all helps! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
A known problem with LR and it can only be rectified by fitting a new gearstick as i was told the machining on pre 2009 gearsticks was way off tolerance... do not accept a grease fix as it will re-occur. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
landyman1 Member Since: 11 Jul 2009 Location: Pembrokeshire,South Wales Posts: 57 ![]() ![]() ![]() |
![]() This and other minor issues dealt with under warranty without fuss---- replaced mirror arm with paint just beginning to bubble, replaced rear worklight with rust appearing on mesh , couple of door screws and a propshaft to rear diff oil seal.reset steering wheel to 12 oclock, was slightly off at 3 mins to 12. Even washed the vehicle all at no charge. Top marks to LIKES LANDROVER at Brecon ( was told that nearly 50% of their sales are defenders so maybe that's why they seem to know what they are doing) Well chuffed with the service ![]() 1986 v8 110 station wagon current 2009 puma 110 xs utility station wagon latest addition |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Im on my third and its started again
still the same..... on second and out of warranty o well
![]() Last edited by fekete on 29th Sep 2010 12:02am. Edited 1 time in total |
Noticed the windscreen hinge that isnt anymore is corroding Mike |
great to feel the love ![]() ![]() ![]() |
I noticed that if you could still get a bonnet mount spare wheel that would be rusting too Mike ![]() ![]() 1968 1/32 scale Britains 109 Pick up. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Willie, which stealer are you using? I have heard good things about Waterford |
First of i was saying I'm on my second new gearstick and now out of warranty ...looking back at the post it doesn't make much sense ![]() ![]() ![]() ![]() |
bhayes Member Since: 13 Sep 2011 Location: Greytown Posts: 4 ![]() ![]() ![]() |
My 2009 Defender 90 Puma gear stick vibration continues, despite THREE new replacement gears sticks. Has any one got an answer has to how to repair this??
Surely by now Land Rover would have had a recall on this or come up with some answer?? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
Some fit a grease nipple on top of the gear stick`s knob
![]() ............................................................. Earth first. Other planets later |
A grease nipple on TOP of the gear stick knob?? - confirm through the rubber knob?, and then confirm the grease runs down the length of the gear stick?? - pretty unsightly?
