Home > Td5 > Rear extra low bumper |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
sorry but this is going to be one dumb looking bumper while providing little protection imho!
7th Apr 2015 9:59pm |
Bosken Member Since: 06 Sep 2014 Location: In the bush Posts: 19 |
Agree 110%. stuped.
7th Apr 2015 10:38pm |
Guessing this is same kind of bar. Rear impact guard. I do see the point, but still.
7th Apr 2015 10:55pm |
How many ultra low sports cars in Spain?as these will be the only cars affected imo.......I cannot see where it could be attached to provide any serious collision protection!this is officialdom gone mad!
8th Apr 2015 12:58am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
How about a standard front bumper and a couple of drop brackets fixing it to the rear cross member , have it a few inches behind and below the cross member, remove the tow hook and I would not worry about the exhaust if you are taking it back off after your MOT. Remove after MOT and refit tow hook (alternatively cut a section out of the standard bumper to allow for the tow hook and put a bend on the exhaust to point it out the side or down and leave the bumper on) . Wont be strong enough to achieve much other than appeasing your MOTer but aesthetically at least it could match the front and look OEM DEFENDER 90 TDCI XS,
8th Apr 2015 5:10am |
Great idea, will try that, actually have the old front bumper i replaced, worth a try
8th Apr 2015 7:38am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Would it be worthwhile having a quick chat with one or two other local 'MOT' inspectors/centres to see if they are pf the same opinion?
Our Defenders pass UK MOT's without issue where there is one minor area which is not safety related but could be a technical failure. However the MOT inspectors are Land Rover savvy and realise the foibles of Defenders. It is down to interpretation of the MOT guidelines. So would a different Spanish 'MOT' inspector have a different interpretation of the guidelines? Might be worth a few enquiries. Have a few words with your local 4x4 club and on the Spanish Land Rover forum and find out what local experience is about this matter. Brendan |
8th Apr 2015 7:58am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Would borrowing and fitting a set of wheels with 205 tyres bring your existing set up low enough ?
8th Apr 2015 8:17am |
Well, this technician was at one of the largest club/garages this day, 4x4 Sahara in Marbella. He always does their vehicles . They always use this dude. What me off is that even with stock shocks (i have 50mm lift) it would still be higher then 55cm from the ground. |
8th Apr 2015 12:36pm |
The whole point is to get it registered with all stuff, and i mean ALL. Here you must register the Snorkel, suspension, bumperettes, wheels etc, all with part numbers etc. And I pay around 700Ģ for it aswell! MOT(ITV in spain) is every 6 month here on this car so there is no way i can rebuild it two times a year. I work with Harley-Davidson down here and you can only imagine what you CANīT do with the most modified bikes in the world haha. |
8th Apr 2015 12:40pm |
Sorry I misunderstood, in your first post you said you would remove the bar after the MOT ...
8th Apr 2015 12:42pm |
I have to, it will look rediculous with it. Its just a pain in the @ss.
8th Apr 2015 12:58pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
I have heard the pain from my mate who now lives in Spain with his 110. Tyres that were 31x10.5x15" (wrong size, should be 235/85/r16), snorkel, towbar with no stamp on it, winch & winch bumper (not the correct one) chequer plate, roof rack spot lights, wrong spare wheel carrier (did not open with the rear door from inside), on board water tank. 1999 Defender TD5 110
8th Apr 2015 1:58pm |
yes, all true. as you can see on my green def on the picture above, the extra work light top right and all the lamp guards has to go as well.
8th Apr 2015 2:07pm |
