Home > Td5 > Rear extra low bumper
Bosken
2001 Defender 110 Td5 CSW Keswick Green
Hi! As i live and Spain with special rules on modified vehicles I need advice / tip how to fab/mount an extra bumper below the stock rear bumper Sad It sux big time, (sure, as soon it has passed the MOT i can remove it, but still).
MAX distance from the ground to the underside of the bumper can only be 55cm (mine is 63cm). The inspector/engineer told me to bolt on a metal bar 10x4cm just under the original one (all because if someone hits me from behind).
This extra bar is but ugly and i wonder if you guys have any idea how to do this so it looks as good as it can,
I attached an illustration (in red) of how it must be mounted, each end must line up with center of tire.
The shape of stock bumper and the exhaust makes it even harder.
Post #414611 7th Apr 2015 10:31pm
nitram17
sorry but this is going to be one dumb looking bumper while providing little protection imho!
Post #414624 7th Apr 2015 10:59pm
Bosken
Agree 110%. stuped.
Post #414639 7th Apr 2015 11:38pm
Bosken
Guessing this is same kind of bar. Rear impact guard. I do see the point, but still.
Post #414641 7th Apr 2015 11:55pm
nitram17
How many ultra low sports cars in Spain?as these will be the only cars affected imo.......I cannot see where it could be attached to provide any serious collision protection!this is officialdom gone mad!
Post #414646 8th Apr 2015 1:58am
LR90XS2011
How about a standard front bumper and a couple of drop brackets fixing it to the rear cross member , have it a few inches behind and below the cross member, remove the tow hook and I would not worry about the exhaust if you are taking it back off after your MOT. Remove after MOT and refit tow hook (alternatively cut a section out of the standard bumper to allow for the tow hook and put a bend on the exhaust to point it out the side or down and leave the bumper on) . Wont be strong enough to achieve much other than appeasing your MOTer but aesthetically at least it could match the front and look OEM DEFENDER 90 TDCI XS,
Post #414661 8th Apr 2015 6:10am
Bosken
Great idea, will try that, actually have the old front bumper i replaced, worth a try Smile
Post #414693 8th Apr 2015 8:38am
leeds
Would it be worthwhile having a quick chat with one or two other local 'MOT' inspectors/centres to see if they are pf the same opinion?
Our Defenders pass UK MOT's without issue where there is one minor area which is not safety related but could be a technical failure. However the MOT inspectors are Land Rover savvy and realise the foibles of Defenders. It is down to interpretation of the MOT guidelines.
So would a different Spanish 'MOT' inspector have a different interpretation of the guidelines?
Might be worth a few enquiries.
Have a few words with your local 4x4 club and on the Spanish Land Rover forum and find out what local experience is about this matter.
Brendan
Post #414700 8th Apr 2015 8:58am
Would borrowing and fitting a set of wheels with 205 tyres bring your existing set up low enough ?
Post #414709 8th Apr 2015 9:17am
Bosken
Brendan
Well, this technician was at one of the largest club/garages this day, 4x4 Sahara in Marbella. He always does their vehicles . They always use this dude. What Censored me off is that even with stock shocks (i have 50mm lift) it would still be higher then 55cm from the ground.
Post #414784 8th Apr 2015 1:36pm
Bosken
The whole point is to get it registered with all stuff, and i mean ALL. Here you must register the Snorkel, suspension, bumperettes, wheels etc, all with part numbers etc. And I pay around 700� for it aswell!
MOT(ITV in spain) is every 6 month here on this car so there is no way i can rebuild it two times a year.
I work with Harley-Davidson down here and you can only imagine what you CAN�T do with the most modified bikes in the world haha.
Post #414786 8th Apr 2015 1:40pm
Sorry I misunderstood, in your first post you said you would remove the bar after the MOT ...
Post #414788 8th Apr 2015 1:42pm
Bosken
I have to, it will look rediculous with it. Its just a pain in the @ss.
Post #414792 8th Apr 2015 1:58pm
excossack
I have heard the pain from my mate who now lives in Spain with his 110. Tyres that were 31x10.5x15" (wrong size, should be 235/85/r16), snorkel, towbar with no stamp on it, winch & winch bumper (not the correct one) chequer plate, roof rack spot lights, wrong spare wheel carrier (did not open with the rear door from inside), on board water tank. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #414804 8th Apr 2015 2:58pm
Bosken
yes, all true. as you can see on my green def on the picture above, the extra work light top right and all the lamp guards has to go as well. Sad
Post #414806 8th Apr 2015 3:07pm
