Home > Puma (Tdci) > Too low Coolant temps? (Warm climate overheat..)
Page 4 of 9 <123456789>
Eduardo
Im quite interested in your findings.
I have the same problem when ambient temperatures are in the 30�C level and at speed of +/- 120kph in a mild slope at 6th gear. (Defender enters in a safetymode and temp gauge goes up)
I have already a larger intercooler and a remap but appears that doesn't help too much. The thermostat and the fan has been replaced at the beggining of this year but I didnt have a chance to try it hard yet (Summer temps are starting now).
So, if the changes doent work I will try the thermostat change.
Cheers Eduardo
Post #375858 2nd Dec 2014 7:01pm
pannawonica
Australia
less than a month and we maybe seeing the 50deg c temps. Anyhow have ordered a thermostat up on evil bay, all I have too do now is get into Karratha Caltex for some red oat and do the deed. Will give a report on how it goes! Thumbs Up Being a 400km trip too the shops it maybe a week or two, but I'm running low on refreshments so you never know. Very Happy
Post #376032 3rd Dec 2014 11:29am
munch90
munch90 wrote:
right ive tried the lower temp thermostat which is a gray one 82o with light spring
only done one shortish run so far results using scangauge
yes is running cooler before would see temps of about 86-90 now about 80-84 mainly 82ish
seemed to take longer to warm up (but maybe never really taken notice of it before )
temp seemed to go up and down by few degrees when warming up (but maybe never really taken notice of it before )
once warmed up seemed to stay bit more steady , but when you put your foot down temp dropped within few seconds by few degrees
temp going up and down bit when first warming up could be bit of air in system ( level has dropped a bit after the run )
don't know about towing as not done any , but before I felt that maybe temp (maybe see 94-96 on a hill ) was up a bit more then I would have liked when towing before
dash gauge never showed any drops or rises as they not that sensitive I think as normally centre postion has quite a large range
Well after a couple of runs , I would say this thermostat is not suitable for uk weather
too long to warm up
temperture goes up nd down to much
if you were doing heavy towing alot it might suit better
so now tried a diffirent one now
cream colour is 86o hard bypass string standard one
gray 82o soft spring warm climate one ? One I tried
so now gone for black one 82o hard spring seems ok so far
Post #377451 8th Dec 2014 10:58pm
pannawonica
Australia
I am now in possession of an 82C thermostat. $50 from Roverload spares AU. Anyhow there's no coolant within 200Ks so it will have too wait. It was 47C yesterday so I'm itching too do the deed. Very Happy
Post #377490 9th Dec 2014 3:50am
Partyranger
South Africa 2009 Defender 90 Puma 2.4 CSW Tonga Green
Pannawonica, it would be interesting to see what you find in those hot climates.
The past couple of days has been about 39Deg C here and my temps were consistenly higher. I however did not have suitable references from before and after fitment so it's hard to say if it is much better.
I would say take the time you've got now to properly document coolant temps vs ambient temps on a few different roads, also speeds and things.
If I push up a hill temps still climb up to 99Deg, I just think the thermostat delays the inevitable a little.
Post #377491 9th Dec 2014 5:11am
pannawonica
Australia
Partyranger that is the question I have been considering, the fact that the thermostat is not increasing the ability of the cooling system too dissipate heat. However the standard thermostat only starts at 88 c too open and is fully open at 94c I think it will be a bit of both. What I mean is a greater tolerance too heat and load, then temperatures going north in the normal way. I will report my findings when get some coolant and fit the 82c thermostat. Thumbs Up Thumbs Up Thumbs Up
Post #378303 12th Dec 2014 2:44am
pannawonica
Australia
Finally got too test the results of the 82deg c thermostat. Took me a while as been a bit crook! Anyhow it was about 46c so I took her out for a burn, at about 130/140 it according too the ultra gauge ( cylinder head sensor) showed 89/ 92. Next day drove down too Perth and the guage showed 82deg to 89deg at the ambient of 35deg. My conclusion is that there is some addition cooling capacity in the Puma's cooling system to be accessed by an 82c thermostat. This thermostat is fully open when the original is only thinking about opening. Going back up too the tropic's too drag a big loaded trailer back down so this mod as far as I am concerned is plenty of bang for my buck ! When I think about it the oils not getting as hot either! Very Happy
Post #408957 19th Mar 2015 1:35pm
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
Thanks for the report Pannwonica! Im interested in doing the same at some stage. I really think the standard thermostat is biased towards emmissions regulations, short trips and cold climates rather than what is best for engine longevity.
You make a good point about the oil temp as well...lowering the temp a bit should make xW-30 oils more suitable for high ambient temps. Although the oil cooler does have its own thermostat, thermal stress on the oil should reduced a bit.
The radiator fan might be a bit out of whack as the clutch will still only lock up when 'air off' temps reach that predetermined point as matched to the standard thermostat.
BUT this means your fan should now run much less, meaning better fuel economy!
This should also help ensuring it doesnt run too cold around town, as even though the thermostat is opening up, the fan wont kick in til things warm right up....its more efficient to first make full use of coolant flow through the radiator before having to use the fan!
Tom
Post #409429 21st Mar 2015 12:31am
pannawonica
Australia
I had not thought of the fan thermostat, however once up too speed ( above @ 40 km/h) the ram air effect will be greater than what the fan can achieve. I have found in the Perth temperatures the engine temperature range is more stable. Yes it takes a little longer too warm up but the cooler ambient air causes less varience too engine temperatures. This reinforces my belief that radiator excess capacity is marginal. Very Happy
Post #409436 21st Mar 2015 2:02am
Beery
Exactly, the fan is really dead weight once you're above town speeds (depending on engine revs/gear selection too).
My theory (and its just that, a theory) is that the fan is part of the problem regarding overheating at highway speeds. At say 110km/h and ~2300rpm with the fan free-wheeling, it is spinning faster than the engine due to the ram air speed. When the clutch locks up and slows the fan to engine speed, it ends up restricting airflow through the radiator. A lower temp thermostat would prevent this problem to a large degree!
I just read some interesting info in the 2012 workshop manual...Apparently the standard thermostat 'starts to open at 82 degrees celcius' and is 'Fully open at 96 degrees'?
This seems to be different to what everyone else is saying i.e. starts to open at 88 degrees?
Post #409437 21st Mar 2015 2:26am
pannawonica
Australia
I cannot confirm the standard thermostat starts too open at 82 deg c from my observations with the ultra guage. The 88 deg standard thermostat goes too slightly above 88 deg then dropped below on first opening. It maintained 88 degrees or above, becoming fully open at 96 degree. I am keeping a cooler cylinder head with the 82 degree thermostat, the 88 deg when pulling on a grade or towing in 45 deg c the 96 deg fully open is a bit to late! Very Happy
Post #409443 21st Mar 2015 5:12am
Beery
I think your observations of 88-96sound more realistic. 82 - 96 sounds like a typo in the manual to me.
Do you notice any difference when driving? Any noticable change sound/power/fuel economy?
Post #409744 21st Mar 2015 10:47pm
pannawonica
Australia
I have notice that in high ambient conditions, 40/50 degree centigrade that after driving for 30 too 120 mins . The engine does not become heat soaked and lose a little power, and become less free revving. I have just driven 1500 kms and got my usual loaded 10/ 10.5 km/ litre. Just had a service and a few jobs done by the stealer and they did n't notice. Next week I will put another 3000 plus kms on it, however so far I have observed no negatives! The thermostat and coolant all up $100 so it would be easy to refit the original, not that I intend so! Very Happy
Post #409777 22nd Mar 2015 3:14am
Grey soft spring thermostat arrived today, truck back so will go on shortly. Off to southern Italy later this year
Post #413298 2nd Apr 2015 8:44pm
Naks
hmm, sounds like a mod I should also do.
FYI, there is also a mod that move the fan closer to the radiator on the 2.4, see http://www.torqtune.co.za/index.php?route=...uct_id=587 --
Post #413303 2nd Apr 2015 8:52pm
