Home > Puma (Tdci) > Too low Coolant temps? (Warm climate overheat..) |
Please buy the thermostat only original
Exists a lot of fake pieces Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Apr 2015 5:30pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Thanks dgardel I wil the fan out! The thermostat was from a reliable Aussie supplier.
5th Apr 2015 12:13am |
PEL500110 (grey soft spring 82°C version) ordered from my Land Rover dealer yesterday. They told me that on their screen it shows up as an original part for the FL II which seems to match the discussion here. It will be installed next week friday when the truck goes in for its semi-annual oil/filter. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 17th Apr 2015 4:03pm. Edited 2 times in total |
9th Apr 2015 1:59pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
I will install mine during the weekend
Let's see what happens Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
10th Apr 2015 8:46pm |
I have the grey soft spring genuine Land Rover one .. Will try and install at the weekend
10th Apr 2015 10:32pm |
I look forward too your impressions of this mod!
11th Apr 2015 1:22am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
Munch 90 is the black one you recommend PEL500110 or PEM101020 Rover forums and internet sellers have confused me. DEFENDER 90 TDCI XS,
11th Apr 2015 5:23am |
PEL500110 is gray one
PEM101020 is black one but if you get them to check stock then go and get them to check colour to make sure , as there have been some mix ups with numbers |
11th Apr 2015 7:19am |
Done, PEL50110 installed today And good thing is that dealer also entirely purged the coolant system and refilled with new anti-coolant mix. So all corrosion inhibitors and other additives are up to snuff again, well before the 10 year prescribed for this job by JLR. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
17th Apr 2015 4:05pm |
How are you going with the new thermostat people?
18th Apr 2015 4:15am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Eric, I am very interested to see what the new thermostat does to the running temeperature.
I was surprised to see that on one of the uncharacteristic warm April days last week(still only 22°), on a faster run, the water temperature crept up to 94° on the Ultragauge. Add to this another ten to fifteen degrees outside temp and a heavy trailer.... 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
18th Apr 2015 10:58am |
All I know is 50degC and a heavy trailer and boiling do we go!
19th Apr 2015 1:15am |
Wild Card, do you have the standard thermostat? If so, what you say is pretty normal I think, as the standard thermostat only seems fully open at 96°C. Now, I may never find out what this PEL500110 gives as a change in running temps. I have no ultragauge, not really interested in it. So only thing I can go by is my standard water temp which does not move above the middle unless you have a boil.... What I would like to add is a simple VDO water temp gauge, one which shows the real water temp, but it seems not so easy to find a spot to install the sensor for that. It has been discussed in an older thread, but without resolution.... http://www.defender2.net/forum/topic28536....water+temp Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 19th Apr 2015 3:01am. Edited 3 times in total |
19th Apr 2015 2:46am |
50°C and a heavy trailer? Not really surprised, are you? That is like trying to cool the radiator by blowing hot air from a hairdryer into it. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
19th Apr 2015 2:53am |
