Home > Puma (Tdci) > Too low Coolant temps? (Warm climate overheat..)
Page 7 of 9 <123456789>
munch90
What I would like to add is a simple VDO water temp gauge, one which shows the real water temp, but it seems not so easy to find a spot to install the sensor for that. It has been discussed in an older thread, but without resolution....
http://www.defender2.net/forum/topic28536....water+temp
Eric[/quote]
could use something like this
eBay item number:
eBay Item No. 131482312461
just to give you a idea , you would need to get right size for hose
Post #417178 19th Apr 2015 8:17am
Partyranger
South Africa 2009 Defender 90 Puma 2.4 CSW Tonga Green
Ok so just as a recap, I have a 2009 defender 90 with 180 000km on the clock.
I've had the high running temps for at least the last 80 000km(since I got my ultra gauge).
I've changed intercoolers, thermostats, bled the cooling system and nothing helped.
Last week I found a small leak on my radiator and decided to replace the radiator with a brand new OEM one.
My temps are now running in the low to mid 80 degree C. At least 10 - 15 deg C cooler than in the past.
I recon, if your vehicle is a little older and starting to run warmer than expected, change that radiator.
I am over the moon.
Post #421620 6th May 2015 6:17pm
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
pannawonica wrote:
After what Dg said I double checked! That's the one I have Ericvv. I have now done several continuous 1500Km runs,( other than fuel stops.) with noworries! Thumbs Up
Still having a good run with that new thermostat, Pannawonica?
Post #440260 24th Jul 2015 10:57pm
pannawonica
Australia
Beery I would not consider going back too the original! However on the ultra gauge I have noticed a slower warm up and not quite as hot heater. Not that it's important. It's winter here so we are seeing 20C or so, had 3ton on the trailer and it did not break a sweat! Very Happy
Post #440378 26th Jul 2015 1:46am
Beery
Great to hear. I'm moving up to Darwin soon so think it might be time for the swap. I've found genuine brand PEL500110 online for $99 in NSW.
Im surprised the warm up time is affected!
Post #440379 26th Jul 2015 2:06am
munch90
Warm up time is affected because its fitted with soft spring allowing more bypass when cold
i found the thè same when i tested it , but i was in uk winter and decided it was no good for uk
Post #440380 26th Jul 2015 5:03am
Beery
Isn't there also an 82c version with a hard spring? Do you know the part number?
Post #440381 26th Jul 2015 5:15am
munch90
part numbers are not always right as some suppliers are using the same numbers for diffirent stats
cream colour is 88 hard spring , standard fitment
black is 82 hard spring , one I found ok in uk
gray is 82 soft spring , I found longer warm up and temp went up and down
all this in uk , of course your temps may given different results
black one (82,hard spring) should be PEM101021
Post #440399 26th Jul 2015 9:18am
Beery
Thanks Munch,
I've just ordered a genuine MG/Rover black PEM101021 from Rimmer Bros. I trust their reliability with part numbers.
We'll see how it goes and I'll compare with Pannawonica's results. In the next month or two I'll be seeing ambient temps in the mid 30's on a run up to Darwin so it will be a good test.
Tom
Post #442336 1st Aug 2015 11:50pm
pannawonica
Australia
In the Pilbara in summer its ordinary too see high 40, 50deg C so I went for the soft spring. I did not want too revisit, the next thing on my mind was some form of uprated radiator. Thumbs Up
Post #442343 2nd Aug 2015 12:48am
dgardel
Italy
we can also use PEM101020: it's open at 82°C, and it has "hard bypass spring" too like the Defender original one. It's better for the warmup phase (shorter)
But I don't know which are the differences from PEM101020 and PEM101021
surfing the web, they seem to have the same features (may be the *020 is superseded by the *021) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #442357 2nd Aug 2015 8:07am
munch90
maybe different make / supplier so number changed ?
Post #442359 2nd Aug 2015 8:19am
ericvv
Interesting that as this discussion started with the soft spring PEL500110 only, it now evolved into the hard spring PEM101020 or 21. Good to know about the latter.
As several on here I have installed the soft spring PEL500110 which should do the main trick, i.e. keeping running temps a bit lower and avoiding (delaying) risk of overheating, which now in summer works just fine. My temp gauge now in summer is moving from cold to normal just as before it seems, not any slower.
I have a good idea how in winter my engine temp gauge goes from cold to normal, so going to watch if there is any slowdown, in which case I might also change to this hard spring 82°C PEM101020/21 thermostat.
Time will tell, as far as I'm concerned, still hoping for an extended summer period. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #442374 2nd Aug 2015 9:39am
Beery
Yes I read somewhere while researching that the 020 is superseded by 021. Same thermostat.
It still makes no sense to me that the bypass spring stiffness affects warmup time. As I understand, it is simply there to relieve pressure on the heater circuit when revs rise and the thermostat is still closed. The bypass, bypasses the radiator, returning coolant from the head straight back to the block i.e. "warmup phase"
Or have I got something wrong...?
Post #442376 2nd Aug 2015 9:50am
Beery
Well it appears I have wasted my money.
My PEM101021 arrived today. The correspondence from Rimmer Bros only began to mention 87 degrees after it had been shipped.
So I did the scientific 'pot-on-stove' experiment with a thermostat and can confirm that it only begins to open at around 87c.
Genuine MG/Rover so its a reliable part number.
Looks like I'll go and fork out for a PEL500110 and keep the 101021 as a spare.
Post #446713 17th Aug 2015 10:08am
