![]() | Home > Puma (Tdci) > Too low Coolant temps? (Warm climate overheat..) |
All recent diesels are running at higher temps for the sole reason of bringing certain emission parameters down, nothing else. Certainly not for lower fuel consumption. Running hotter is long term not necessarily better for the engine though. The PEL500110 therefore is a sensible improvement. And an engine running at lower 80's coolant temps is not exactly a cold engine, just normal, so fuel consumption should not be higher at these temps.
If you have 15 l/100 km fuel consumption it must be something else that is wrong. How are your exhaust fumes by the way? Normal, or black sometimes? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
I haven't noticed any black smoke but the exhaust pipe gets black soon after I clean it.
Maybe part of the problem is that I use the car only 3-4 times a year and make long trips. In my understanding that should be good not bad, but... You know... an organ which is not used, disappears... |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Are you saying that a Defender is not designed to be able to drive at 130km/h on a hot day without overheating? Which other make/model of car has this problem? Because, I have had one that could do it and one that could not do it at first (until I changed the engine after the head gasket blew twice). I think there must be something wrong with the cars that can't cope with the speed/heat. I towed a fully loaded Ifor Williams trailer at 100km/h through Namibia (hot days and aircon on) and temp on the ultra gauge never went over 100 Degrees and the car is still fine. After the trip I did find some grass/mud blocking part of the radiator and it obviously did not immediately kill the engine during the trip or afterwards. I wish we could find the solution for this "overheating" problem as its always there in the background as a concern. I also wish we knew what specification (temperature) the Puma engine in the defender was tested for or calculated for? Would be interesting to know if its a lesser specification than a Discovery 3 for example. You would have expected that as a commercial vehicle for harsh environments the specifications would be tougher than a Discovery 3.... 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
To a degree I am a little to blame for the overheating problem, remap 40%@ more power more heat. Bull bar and spotlights insect screen restricting airflow. It can be said many other vehicles have that and more without problem. Generally with heat mitigation mods it's not an issue except when towing, however when time comes for a new radiator I'd look for a serious upgrade!
