Home > Puma (Tdci) > 2.4 tdci - BIODIESEL
Page 3 of 4 <1234>
Caterham
Harvey
if you're evey in b'ham you'd be passing my place.
if you want to call in and show off your truck I'll run you through my 'oil refinery'.
Post #40000 6th Sep 2010 8:51pm
harveyg77
I will take you up on that offer as I am only in Derby. Which side of Birmingham are you? I am toying with a trip to Coventry (JE Eng) to test drive their 90 to see how much the ride is improved with their suspension setup.
Thanks
Harvey
Post #40005 6th Sep 2010 9:03pm
Caterham
(your side - A38)
nr Asda @ Minworth.
feel free to drop me a PM and I'll send you my address / mobile number.
Post #40023 7th Sep 2010 6:54am
pom
Caterham
Are you making bioD ? If so which processor did you build/buy ?
cheers
Pom
Post #40030 7th Sep 2010 8:08am
Caterham
yep
a BD450 by future fuels.
Post #40049 7th Sep 2010 11:55am
pom
you have a link for it ?
How are you pulling all the meth out of the brew ?
Pom
Post #40059 7th Sep 2010 12:44pm
Caterham
looks like their are opertating under a different name.
http://www.biodiesel-fuel.co.uk/range/FF450.asp
meth is released through bubbling the bio diesel after settling the glycerol out over several days then a final 'wash' with eco2pur.
then a final 3micron filter.
Post #40109 7th Sep 2010 7:03pm
pom
oh dear, I wouldn't put that in anything expensive as its going to have too much meth left in.
That's a pretty old design. Have a look at Graham Laming's build from the link below. By far the best system I have seen, he condenses the meth out so no Censored about with days of bubbling and hoping its gone.
It's not that bad to build if you can do some basic plumbing.
http://www.graham-laming.com/bd/main.htm
Pom
Post #40110 7th Sep 2010 7:14pm
spudfan
Ireland
One thing you need to consider with bio-diesel are the customs and excise boys. I phoned our lads up and asked whether it was legal to use cooking oil in my series 111. They said I could use anything I liked provided I paid the duty that would be levied on road fuel to what ever I was putting in the tank. If stopped and dipped-this does happen- I would have to prove that I had paid the correct duty for road fuel on whatever I had in the tank. The penalties for non compliance are severe. Vehicle would be lifted and a court appearance would follow. Cannot see your boys been lax about this issue either. Best to check before you put it into the tank. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #40154 8th Sep 2010 10:09am
harveyg77
Spudfan,
Correct, this is an area which needs to be complied with. However, my understanding is that the UK (well England and Welsh) government introduced a scheme where you can use 2000 litres (or whatever the figure is) a year duty free, anything beyond this requires a self-declaration form and cheque submitting to cover the revenue.
Its all a part of the detail I need to look into should Caterham and Porn convince me to go ahead Wink
Harvey
Post #40156 8th Sep 2010 10:28am
spudfan
Ireland
Harvey, your customs and excise boys seem to have a more relaxed view than ours. 2000 litres allowance a year seems pretty generous to me. If our lads thought the same I would give it a go.Then again it might be worth phoning them up once in a blue moon to tell them you are using 45 litres of cooking oil for road fuel and what is the duty due on it! 1982 88" 2.25 diesel
Post #40157 8th Sep 2010 10:34am
harveyg77
In our household my wife, 6-month old daughter and I would in theory be able to access 6,000 litres which should give a good 35k miles a year coverage (for the Defender), but seeing as I am averaging about 600 miles/month, I think I am safe for a while Wink
Harvey
Post #40160 8th Sep 2010 11:21am
pom
If your interested in bio, then i would advise looking at the link i made above. Graham's system is the best one I've seen and that includes the commerical ones.
You need a couple of old immersion heater tanks and your good to go.
Pom
Post #40182 8th Sep 2010 3:46pm
Caterham
pom - was doing a search and came across this again.
it got me thinking. the graham method is that it job done?
as you mentioned with mine there would be alot of meth left in the mix. I don't think I mentioned that what comes out of my processor is 'raw bio', I then dry wash it using Ecopure (wood chippings) to absorb left over chemical residue.
my only real measure of if this ok or otherwise is my wifes common rail injection has done 28k miles over almost 3 years without issue - that includes 100% bio through the winter too !
Post #58288 10th Feb 2011 3:24pm
pom
condensing it out is the best method by far. When i was more active making it, all the forum threads looked down on bubbling or scrubbing methods as they were not 100%.
Pom
Post #58309 10th Feb 2011 4:42pm
Page 3 of 4 <1234>
