Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 9 of 11 <123 ... 8 91011>
Tiger
Alternator
Post #359077 20th Sep 2014 2:30pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
I took mine from the alternator because i mounted my relays on the metal bracket located on the wind which is very close to the alternator. Everything seems to be working well and with Osram nightbreakers and crystal headlights the light output is much better cant recommend this mod enough. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #359102 20th Sep 2014 4:32pm
Dave k
I've just fitted the Red Bison loom to my 110, & it's made a drastic difference to the lighting output.
In fact, the only time I've better lighting was when the voltage regulator failed on the alternator.
16v does tend to give superior lighting!
Luckily, I didn't blow any bulbs. Rolling Eyes Ex RN 110 Station Wagon
Never Raced or Rallyed
Post #373916 24th Nov 2014 2:47pm
Cheshire110
excuse my novice but where/how would i take the +ve feed from the alernator?
Where/what connection etc? cheers in advance Thumbs Up Cheers, David
Post #397770 10th Feb 2015 10:23pm
munch90
The big lead , normally 13mm nut
Post #397775 10th Feb 2015 10:37pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Is that alternator feed only live when the ignition is switched on?
Post #397785 10th Feb 2015 11:05pm
munch90
No main big lead is live all the time
Post #397790 10th Feb 2015 11:12pm
kmac
Thanks munch
looking for a chunky switched source other than the cigarette lighter
Post #397791 10th Feb 2015 11:13pm
munch90
Wire from battery then use cigar lighter feed to switch relay
what you wiring up ?
Post #397794 10th Feb 2015 11:16pm
kmac
Good idea thanks.
Not really wiring up anything at the moment.
Got one of those mini fuseboxes with 12 positive terminals and a negative bus bar
Going to put a couple of items currently wired to the cigarette lighter onto it ( couple of USB chargers)
Post #397798 10th Feb 2015 11:31pm
munch90
fuse the wire near to battery then to aux battery via relay Thumbs Up
Post #397811 11th Feb 2015 8:11am
Happyoldgit
Just fitted a Landreiziger loom to my newish 2.2 - easy peasy.
Remove grille [in my case aircon], front indicator lamps, sidelamps, light surrounds, headlamps [inc bowls taking care not to disturb beam alignment screws], top radiator shroud.
The twin Ripaults are relays mounted using one of the existing holes in the inside lip of the R/S wingtop via a clip on speed-nut and large self tapper. This location means the twin fuses are easily accessible.
Prior to fixing the paint was removed from around the mounting hole and anti corrosion gel applied, the self tapper provides the - earth point.
+ feed taken from alternator, cable provided with additional conduit, looped and secured via cable tie using existing hole in steel wing support bracket.
Harness runs behind airbox in additional conduit.
Switching feed taken from existing R/S headlamp connector which are then wrapped in self amalgamating tape.
L/S headlamp feed runs across top of intercooler tucked under plastic lip and into L/S headlamp. Now redundant original headlamp connector is wrapped in self amalgamating tape.
Test & reassemble. Job done. Steve.
http://forums.lr4x4.com
Post #407730 15th Mar 2015 1:16pm
bob neville
Not sure if this has been mentioned before, apologies if it has.
I have been using the Red Bison loom for 3 months without any issues.
Monday, no headlights at all, not even when flashed Shocked
Tuesday they were working again without any intervention on my part.
Today, they stopped again. Just checked the fuses and relays under the steering wheel, all OK.
Had a play with the two relays in the RB loom and they had both come lose, enough to stop the headlights working. Pushed them fully home and I have lights again. I will have a good look this evening to see what is going on.
Probably just need the female recptors closing a bit to get a better fit.
2013 Defender 90 CSW - sold
Post #408969 19th Mar 2015 2:19pm
munch90
if the relays have been removed at some time people always me included move relay side to side to remove also same with headlight connectors making the connection looser
just give the terminals a quick tweak with small screwdriver when refitting
Post #408970 19th Mar 2015 2:24pm
jst
Tiger wrote:
Right so I've been and had a look and it's not that the pins are wrong but the basic loom is incorrect in principle.
It uses a 5 pin relay to switch power between 87 & 87a when switching Dip to Main.
This works fine as it isolates each circuit on the switch, the problem is that 'Flash' activates both circuits at the same time, the ebay loom prevents this.
So basically the loom needs to be modified to 2 standard relays and the 'Main' relay needs it's own fused power source or a jumper from the Dip relay. (As per Dan Thumbs Up )
Tiger - could you do a wiring diagram of what it comes like and what you modified it too please? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #411172 26th Mar 2015 6:38pm
