Home > Maintenance & Modifications > Fitting a new aerial? This may help....
I have just replaced the aerial on my Puma DC, and to avoid having to strip out the dash etc to run the lead for the new aerial back to the radio, I bought a female in-line aerial socket from Maplin for a massive £1.99.
This meant that I simply cut the lead off the old aerial and fitted the socket adjacent to the aerial location. Subsequent replacements (and I am sure there will be more) will be very simple.
I don't know why on the Defender LR didn't use the same technology as on the D2 - an aerial integrated with the window glass. Totally vandal resistant and tree-proof.
Post #39731 3rd Sep 2010 10:37pm
K9F
Great tip! I always lower mine when leaving the vehicle unattended to prevent some scrote from vandalising it, subsequently the top two sections are worn and will no longer stay up for long, may have to look at a replacement myself soon! Did you fit a standard replacement or go for something a little more robust?
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39734 3rd Sep 2010 11:12pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
I'm looking for a flexible aerial....I've found the one of Nakatanenga but I don't like it so much....some of you know something better?? Matteo
Defender 110 Td4 SE MY 09
Post #39759 4th Sep 2010 6:30am
Re: Fitting a new aerial? This may help....
Probably because not all defenders have "side" windows (where the aerials are usually mounted).
Front screen would probably limit vision; wind up door windows would probably break the cable eventually.
I reckon the only decent panel that would do, would be the alpine roof glass, but not all rovers have these.
Post #39760 4th Sep 2010 7:57am
John051
Belgium 2010 Defender 110 Puma 2.4 XS CSW Java Black
90% of the time I drive around with the aerial down and get a good radioreception. Only on long trips or in rural area's I pull it up.
Post #39762 4th Sep 2010 8:10am
pom
why not fit an electric one ?
Pom
Post #39763 4th Sep 2010 8:17am
dgardel
Italy
Ya Pom
I fitted an electric one, so you can decide how extend it..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #39776 4th Sep 2010 10:17am
