Home > Maintenance & Modifications > Fitting a new aerial? This may help.... |
Great tip! I always lower mine when leaving the vehicle unattended to prevent some scrote from vandalising it, subsequently the top two sections are worn and will no longer stay up for long, may have to look at a replacement myself soon! Did you fit a standard replacement or go for something a little more robust?
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Sep 2010 10:12pm |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
I'm looking for a flexible aerial....I've found the one of Nakatanenga but I don't like it so much....some of you know something better?? Matteo
Defender 110 Td4 SE MY 09 |
4th Sep 2010 5:30am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6102 |
Probably because not all defenders have "side" windows (where the aerials are usually mounted). Front screen would probably limit vision; wind up door windows would probably break the cable eventually. I reckon the only decent panel that would do, would be the alpine roof glass, but not all rovers have these. |
4th Sep 2010 6:57am |
John051 Member Since: 13 Aug 2010 Location: Antwerp Posts: 24 |
90% of the time I drive around with the aerial down and get a good radioreception. Only on long trips or in rural area's I pull it up.
4th Sep 2010 7:10am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
why not fit an electric one ?
Pom |
4th Sep 2010 7:17am |
Ya Pom
I fitted an electric one, so you can decide how extend it..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Sep 2010 9:17am |
