Home > Maintenance & Modifications > Wheel bearing change |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
It's been some time since I've done that job but does the shaft have an internal thread in it that you can put a bolt in and pull the shaft out ? I think shaggy dog had a similar problem a week or so back and took out the opposite shaft and pushed a length of copper pipe through to push the shaft out !
Necessity is the mother of invention 2005 Td5 90 XS Steve |
25th Jan 2015 11:02am |
Craig Member Since: 10 Oct 2014 Location: Portland, Dorset Posts: 18 |
Yep, I had a bolt in the thread and a slide hammer on it and it didn't budge! Would be a right pain in the arse to strip the other side down to push this one out, and what then if the other side did the same apon reassembly??? Something I could try if all else fails! Why is it the simplest jobs turn out to be the most problematic?
25th Jan 2015 11:07am |
How about removing flange and shaft and assembling them together then put the shaft back in with the flange already on it ? 2005 Td5 90 XS
Steve |
25th Jan 2015 11:10am |
Take it you might know this but normally screw a bolt in the centre then just pull out by hand , you want need a slide hammer normally ( well i never have anyway
Cant remember if the thrust washer for the cv has a wrong or right way round , some washers have a tapered inner |
25th Jan 2015 8:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17473 |
Are you absolutely sure that the hub assembly is back on the stub axle correctly? If for some reason the hub isn't seating correctly (ie it hasn't gone on far enough) - for example if the outer race of the inner bearing isn't properly installed - you would have this problem. I can't immediately think of any other reason.
25th Jan 2015 10:33pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Nice 1997 or 1998 CT Defender
As said above I think your bearings are not installed correctly. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
28th Jan 2015 7:13pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8096 |
just take the hub off and try and pull it out, if still wont come take stub axle off and check seating in back.
Sometimes they get pushed in on assembly and dont come back out until it is stripped again, just keep hold of it on the 2nd assembly. probably nothing fitted wrong, its just been stubourn. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Jan 2015 8:14pm |
Thanks for all the suggestions really appreciated, I will have it part again hopefully this weekend and try some stuff out. Cheers
28th Jan 2015 8:42pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Ok, it's beat me. How on earth did you get the truck up on those front stands? Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
29th Jan 2015 4:03pm |
I'm guessing with the other half of the ramp setup that's still holding the wheel just at the right of the picture
29th Jan 2015 4:09pm |
use the other pair of colum lifts ( you can just see the other one with the wheel still on it ) lift on the wheel then lower on to stands then remove the wheels
Agh, right I can see now. Didn't notice the ramps moved out of the way Craig Rogers
29th Jan 2015 4:14pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
I assume they're not new drive members? (The earlier thicker ones vs the later thin ones?)
29th Jan 2015 4:38pm |
