Home > Maintenance & Modifications > Wheel bearing change
Craig
Had to change the wheel bearing for the MOT, I also changed the hub oil seals as they where leaking. The only thing is when I got it all back together I couldn't get the half shalf out enough to put the C clip back on, the driving flange was on and bolted down, I could feel the groove that the clip sits in with a finger nail but not enough was protruding the driving flange for the c clip to locate into. Any ideas on where I've gone wrong?
Post #392326 25th Jan 2015 11:45am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
It's been some time since I've done that job but does the shaft have an internal thread in it that you can put a bolt in and pull the shaft out ? I think shaggy dog had a similar problem a week or so back and took out the opposite shaft and pushed a length of copper pipe through to push the shaft out !
Necessity is the mother of invention Thumbs Up 2005 Td5 90 XS
Steve
Post #392328 25th Jan 2015 12:02pm
Craig
Yep, I had a bolt in the thread and a slide hammer on it and it didn't budge! Would be a right pain in the arse to strip the other side down to push this one out, and what then if the other side did the same apon reassembly??? Something I could try if all else fails! Why is it the simplest jobs turn out to be the most problematic?
Post #392330 25th Jan 2015 12:07pm
Lou Sparts
How about removing flange and shaft and assembling them together then put the shaft back in with the flange already on it ? 2005 Td5 90 XS
Steve
Post #392331 25th Jan 2015 12:10pm
munch90
Take it you might know this but normally screw a bolt in the centre then just pull out by hand , you want need a slide hammer normally ( well i never have anyway
Cant remember if the thrust washer for the cv has a wrong or right way round , some washers have a tapered inner
Post #392563 25th Jan 2015 9:26pm
Are you absolutely sure that the hub assembly is back on the stub axle correctly? If for some reason the hub isn't seating correctly (ie it hasn't gone on far enough) - for example if the outer race of the inner bearing isn't properly installed - you would have this problem. I can't immediately think of any other reason.
Post #392607 25th Jan 2015 11:33pm
roel
Nice 1997 or 1998 CT Defender Thumbs Up
As said above I think your bearings are not installed correctly. Roel
2003 90 Td5 (2009-now)
Post #393400 28th Jan 2015 8:13pm
jst
just take the hub off and try and pull it out, if still wont come take stub axle off and check seating in back.
Sometimes they get pushed in on assembly and dont come back out until it is stripped again, just keep hold of it on the 2nd assembly.
probably nothing fitted wrong, its just been stubourn. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #393421 28th Jan 2015 9:14pm
Craig
Thanks for all the suggestions really appreciated, I will have it part again hopefully this weekend and try some stuff out. Cheers
Post #393440 28th Jan 2015 9:42pm
x-isle
Ok, it's beat me. How on earth did you get the truck up on those front stands? Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #393696 29th Jan 2015 5:03pm
mk1collector
I'm guessing with the other half of the ramp setup that's still holding the wheel just at the right of the picture Mr. Green
Post #393698 29th Jan 2015 5:09pm
munch90
use the other pair of colum lifts ( you can just see the other one with the wheel still on it ) lift on the wheel then lower on to stands then remove the wheels
Post #393699 29th Jan 2015 5:09pm
x-isle
Agh, right I can see now. Didn't notice the ramps moved out of the way Craig Rogers
2007 Puma 110 XS
Post #393701 29th Jan 2015 5:14pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
I assume they're not new drive members? (The earlier thicker ones vs the later thin ones?)
Post #393711 29th Jan 2015 5:38pm
