Home > Maintenance & Modifications > Stainless steel EGR blanking kits
Page 12 of 16 <123 ... 111213 141516>
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
big steve wrote:
ok nice one robo is the light coming on though
i was thinking along those line but a machined peice about 10mm thick with a hole drilled with a union of to a breather or sonething ?
using a blanking plate to block the manifold
altho you would havt to only use th manifold bolts to hold the egr on without a supporting bolt im shure it wont hurt ?
steve
any one got down to the 10mm hole yet
No light steve ! but this method does need alot more testing. i agree to machine a chunky block of steel with an induction port and pipe would work. I was trying to come up with something that would not get noticed at dealer vists or as easy as one of my blanks to take out Thumbs Up Question Question any ideas anyone 2008 110 County utility
ex 1988 defender 90 ,td
ex 1970 series III
Post #37554 2nd Aug 2010 10:31pm
dgardel
Italy
Robofarmer wrote:
dgardel wrote:
If can help ypu, I'm on project!!!!
Hi dgardel i,m driving to italy the beginning of august about the 14th i should be there for a fortnight maybe we should meet up ? Thumbs Up
Embarassed I'm in Germany fro 9 august to 14......
Could you "move" the day?
anyway I PM you my mobile number and email ..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #37557 2nd Aug 2010 10:59pm
Robofarmer
Thats fine dgardel like i say i,m in italy from the 14th until 26th ,ish Thumbs Up I will give you a call later today. 2008 110 County utility
ex 1970 series III
Post #37565 3rd Aug 2010 6:32am
Tim seymour
Australia
hi well i fitted the 16 mm plate to day. took 2 hours as i have ac . went for a small drive no light as yet it does sound quiet and has better throttle responce. ps can some one tell me if have to loosen the holding bolt or do you just undo the two ss bolts and slip the next plate in cheer tim hope you can understand all that Smile Cess the Taswegian
Post #40310 10th Sep 2010 10:00pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Tim,
I fitted the 10mm plate yesterday and I had to loosen the bolt on the right side of the engine to get enough room to pull out the previous plate and fit in the 10mm plate.
I haven't been out on the road to try it out yet. Hopefully the light won't come on when I do!
I will post again later once I've done some miles.
Daz110
Post #40330 11th Sep 2010 4:02pm
Tim seymour
Australia
thankyou das i will also post a reply when i get some more km up it will be about 2 to 3 week cheers Smile Cess the Taswegian
Post #40352 11th Sep 2010 10:54pm
DAZ110
My MIL light has now lit after fitting 10mm blanking plate and traveling about 600 miles Sad
Time to try the 12mm plate I think?
Post #41175 23rd Sep 2010 7:54pm
Tim seymour
Australia
hi daz iam still on the 16 mm done about 500km i have safrai snorkel seams to be going very well the fuel is better i was getting about 10.5 to11 liters per 100km am now on 10 will try a smaller one in about a 4weeks cheers tim let us know how the 12 mm gose Smile Cess the Taswegian
Post #41195 24th Sep 2010 6:49am
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Jumping in on this conversation, I have a 110 Stormaway XS utility that is almost the twin of the one pictured in this conversation. I have had the 12mm plate fitted for about the last 500 miles and my light has now come on, so will move up to the next size when I get a chance. Also have BAS remap, Safari Snorkel, ITG air filter, Allisport hoses and straight through centre pipe...
Post #41245 24th Sep 2010 7:12pm
K9F
Bigfog,
I have a similar set up to you and am running 10mm have no MIL light, (it did come on once with a P1103 code which I reset and has not reoccurred) it may just be a one off???? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41247 24th Sep 2010 7:18pm
BIGFOG
Could well be, but how can I clear the fault to see if it happens again, all I have is the BAS mapping tool which I understand can read the codes, but not sure if it will clear them as well - short of that the car has gone beautifully since the plate went in. Thanks for the input.
Post #41249 24th Sep 2010 7:23pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
The BAS interface mapping tool will clear codes Thumbs Up Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41254 24th Sep 2010 8:01pm
BIGFOG
Many thanks Fekete, I'll give it a go, it's got to be easier than changing the plate out, especially as it's dark and wet outside now.
Post #41255 24th Sep 2010 8:04pm
fekete
Just go in to read codes when the codes come up just scroll down to clear codes Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41256 24th Sep 2010 8:19pm
DAZ110
Looks like I will try that as well. Thumbs Up
Post #41271 25th Sep 2010 7:54am
