Home > Technical > Rear Reverse/Fog Lights
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Hi all,
I have a 2008 110 DCPU. I'd like to add some additional rearward illumination for reversing, so I am thinking of adding an extra reverse light on the other side of the vehicle (along with an extra fog for symmetry).
What would be involved with this (apart from drilling extra holes for the connector and mounting screws)? From what I have read, there are spare connections for reverse and fog on each side for RHD/LHD configurations. Are these plug and play affairs?
Cheers! Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #374235 26th Nov 2014 2:14am
munch90
when I done mine ( 90 ) I cant remember any extra plugs or sockets , be honest cant remember looking for extra sockets
I just spliced into standard wiring and in one bit of corrugated tubing ran one pair to one side and one pair back up along inside rear cross member , I was using led lights so had no problems with extra load etc
one tip if your doing it on a hard top is to measure/line up and cut hole on the drivers side first because of the door hinge , if start on the passenger side and leave too bigger gap between reverse light and new fog light when you get to drivers side the fit the extra reverse light the hinge can be in the way to get the same gap to look even both sides
I very nearly got caught out by this
Post #374237 26th Nov 2014 6:52am
SailingTom
As above mine was also spliced into the existing, I didnt see any plug and play bits unused on my current 90, but wasnt really looking. Nice simple job that works well, as you said make sure there lined up though nothing worse than them being wonky.
 Defender puma dormobile camper
Post #374247 26th Nov 2014 8:15am
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
My 200tdi 110 and TD5 90 both had the wiring and connectors there already 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #374258 26th Nov 2014 9:48am
If you do the double up mod you can make up a small loom with proper connectors leaving the original wiring 100% intact.
The are called 2 pole Econoseal connectors.
Post #374259 26th Nov 2014 9:54am
PaulMc
Earlier vehicles were pre-wired to accommodate both RHD and LHD fog and reversing lights, making it very easy to double-up the rear lamps.
This was changed to dedicated RHD and LHD harnesses at some point during TD5 production.
It's pretty easy to make-up the wiring to double-up the fog and reverse lamps - but, if you don't want to make them yourself - then, MUD UK make a 'piggy-back' loom for doubling-up rear lamps -
http://www.mudstuff.co.uk/products/electri...-loom.html
They're not ideal - but, they give you a good idea of how easy it is to make something suitable.
. Paul.
Post #374277 26th Nov 2014 12:00pm
PCA42
Thanks for those replies chaps Thumbs Up plenty of food for thought there then. I had been looking for those piggy back connectors and had no luck, so thanks for reminding me of where. Do we reckon the wiring would take the extra load of another lamp, since I want to use standard filament units? Pete
Post #374287 26th Nov 2014 12:49pm
JWL
Mine work perfectly fine and I've gone back to standard filament bulbs.
Post #374289 26th Nov 2014 12:58pm
Martin
Site Admin
Assuming you are using bulbs, each lamp is 21W. Doubling up is 42W - at 12V this is 3.5A current draw.
The wiring to the rear lights is 1.5mm^2 - rated at 20A (bit less for long lengths).
So there's plenty of spare capacity in the cable Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #374291 26th Nov 2014 1:18pm
PCA42
Lovely, thanks lads. Sounds like I'll be ordering an extra pair of lights! Bow down Pete
Post #374292 26th Nov 2014 1:22pm
munch90
I thought about making up a link loom , but your never going to remove the extra lights after you have cut holes in the bodywork anyway , so I didnt worry about splicing in to stardard loom , just soldered and heat shrinked with glue lined shrink to watherproof
Post #374379 26th Nov 2014 7:18pm
The scariest part of it would be putting a hole saw to it I'd imagine. Shocked
Post #374385 26th Nov 2014 7:34pm
munch90
yes unless you have a towing socket then could be 3 bulbs when towing , but still within limits Thumbs Up still only 5.25a
Post #374390 26th Nov 2014 7:42pm
munch90
if your using led lamps then you dont need to cut a hole as large as the original hole as there is no bulb holder to sit in the hole as the back of the led lamp is flat
Only thing is normally the lamp plinth is held by nuts on the back with only small hole you need access to the back , with a large hole you can tighten through the hole
I cut large hole ( think it was about 30-40mm ) and done all wiring from outside without having get at the back of the lights
Post #374400 26th Nov 2014 8:14pm
PCA42
Today I finally got round to fitting the pile of bits to do this that were sat on my workbench!
First I marked up the holes for the plinth fixings, drilled these with a 5.5mm bit, and then measured between the two using a ruler and marked the half way point. Here I used the 5.5mm to drill a pilot hole, and then used a hole saw to cut the large hole for the bulb holder to go through (I didn't have quite the right size, so I had to file it out slightly for it to fit nicely).
Then I moved the fog lamp to the inner hole, and then screwed the new 2nd reverse lamp into the outer.
Repeat for the other side, but the reverse is already the outer lamp so no moving them around.
I then made a small loom up approx 55" long, using MudStuff piggy back connectors (so the factory loom didn't need to be modified on the vehicle), and the bulb connectors as supplied with the lights. Shrouded by plastic sheathing as per the existing loom.
Then it's just a case of 'plug and play', making sure the connectors are to the right ones (hence I used coloured tape). Tidy up with zip ties and replace the mud shields.
And test. Bobs your uncle, twice the reverse and fog illumination! Result Thumbs Up
NOTE: I have the LED reverse lamp bulbs as detailed in another thread, but I'm not sure these are actually any brighter than the filament bulbs.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #427182 29th May 2015 10:56pm
