![]() | Home > My Defender > Overland 110 Build from the Ground Up! |
BigM Member Since: 12 Nov 2011 Location: Nairobi Posts: 36 ![]() ![]() ![]() |
You bet we do. I vote this best story and presentation in a long long time.
Thanks for the effort. |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 725 ![]() ![]() ![]() |
This is fantastic, well done on your perseverance in quality, btw are the utility sides 88" series 3 sides? Hoping to do the same on a 110 CSW I've just bought.
Keep it up, lets see more! Cheers. Alex |
Defender_Td5 Member Since: 20 Jul 2009 Location: Devon/Australia Posts: 69 ![]() ![]() |
Hi Alex,
Yes, Series 3 88" sides will fit your 110 CSW. I considered going down this route myself, however the utility body turned up at the right time. More pictures and info to follow! Thank you all again for all of the replies. Cheers Rob Defender 300Tdi 110 Utility Wagon ROW Overland Series 1 86" |
Right then on with the build!
The second row floor was painted in Stornoway Grey and the underside was given a good coat of black underbody paint and then covered with heat reflective soundproof matting. The gasket running around the edge is EPDM foam sealing strip. ![]() Click image to enlarge The headlining was fitted (with more sound proofing underneath) and the same was done to the utility sides, these were then covered with a layer of much thicker matting as well to finish them off. The black sealant around the edges was to seal the frame to the aluminum skin. You can also see the internal window guards all fitted in place: ![]() Click image to enlarge ![]() Click image to enlarge The rear inside of the tub was shaping up nicely; here is it before installation of the rear storage draw arrangement. ![]() Click image to enlarge ![]() Click image to enlarge It was a big day, but I finally managed to get the remaining four doors on the truck and the Mantec rear wheel carrier fitted. The tinted rear windows were supplied by Masai Parts: ![]() Click image to enlarge The puddle on the floor is where I filled up the windscreen washer bottle and bled the system through! ![]() Click image to enlarge A few pictures showing the insides of the doors and how the soundproof matting was added. This has made a big difference to the Defender door shut noise, transmission of road noise and it doesn't interfere with the electric window winders either. All the door frames were injected with Waxoyl at this stage as well as a further rust prevention effort: ![]() Click image to enlarge ![]() Click image to enlarge Here is the interior almost done. Fitting the front soundproof matting was not fun as it is so thick and seriously strong, makes it difficult to cut with even a new Stanley knife blade. However if you use washing up liquid on the blade, it makes a big difference! Once all done though I do think it looks good. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The bonnet was fitted in place, a Warn 9.5CTI winch added and the rock sliders bolted up. I finally finished off the remaining bodywork with the addition of the small quarter panels located just behind the second row doors. A D44 steering guard was also added to complement the bumper. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I was running out of time now as I had to fly back to Australia, so the truck went off for it's MOT (having put the front number plate on). It passed first time; I was very chuffed to say the least. After 3 weeks of solid build time in the barn it had gone from a drivable rolling chassis with just the bulkhead in place to as you see it now. The Hannibal roof rack was added and that's pretty much as it was when I left the UK at the end of that trip back. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Here are a few underside shots: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge At this point there was still lots to do but the really hard work was now done. I had an external roll cage ready to be fitted, but I just didn't have the time to fit it myself, so it was arranged that the Defender would go up to Devon 4x4 to have the cage fitted as well as the snorkel. They would also carry out some other little jobs on the list that weren't completed. Final few pictures before my departure from the UK. ![]() Click image to enlarge ![]() Click image to enlarge More to follow! Regards Rob Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Series 1 86" |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Every defender enthusiast dreams of the budget and space to do this.
Enjoy it ! ![]() |
Craig Member Since: 10 Oct 2014 Location: Portland, Dorset Posts: 18 ![]() ![]() |
Brilliant, I have just read this from start to finish, you've done an amazing job and I look forward to seeing more on your landrover.
captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 356 ![]() ![]() ![]() |
Congratulations, Rob! this is awesome and a great read to boot.
![]() ![]() Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
exceptional build!
![]() ![]() ![]() ![]() my youtube channel |
Dave Member Since: 30 Aug 2007 Location: Wiltshire Posts: 165 ![]() ![]() ![]() |
Wow, better than a new vehicle
![]() "What is the first rule when overlanding?" I would Reply: "Duratrac" |
dlks151 Member Since: 30 Jun 2014 Location: Auchinloch Posts: 67 ![]() ![]() |
Congratulations on such an outstanding build, no corners cut
Thank you for continual praise! I will endeavor to try to keep you all happy by continuing the write up....As one of the last posts stated the truck was heading off to D44 to have a roll cage, snorkel, roof rack support and lots of other jobs that I just didn't have the time to do before I had to leave the country for Aus again.
The following is a collection of pictures taken by D44 during their part of the build, all credit goes to Martin and Jake for doing a truly stunning job on the truck and I must say the care and attention taken by all the team at D44 is second to none! Rear storage draw as fitted by me in the truck before it arrived at D44, this was a semi custom job built by Mobile Storage Systems, with black powder coated draws and matching checker plate. There is also a smaller storage chest with a pop up top located behind it: ![]() Click image to enlarge D44 Work: Roll cage starting to be fitted on the rear most section of the truck: ![]() Click image to enlarge ![]() Click image to enlarge Progress from the front: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Rear roof access ladder: ![]() Click image to enlarge The roll cage bolts through the rear tub and passes down to rear chassis mounts: ![]() Click image to enlarge ![]() Click image to enlarge Mid-mounting points for the cage: ![]() Click image to enlarge Rear speakers modified to allow the cage to pass through: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Rear tub picture which shows part of the cut out that I had to make to allow the Puma 2nd row rear seats to mount correctly to a Tdi/Td5 rear tub and the aluminum infill: ![]() Click image to enlarge Rear Tdci dog guard fitted with some slight modifications to a non-Puma body: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Snorkel mount to pass through wing: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Protection and Performance Snorkel goes on: ![]() Click image to enlarge Breather pipes hole cut into wing top: ![]() Click image to enlarge ![]() Click image to enlarge Finished: However, the cyclone top pictured here was later replaced with a larger diameter one as it was found that the smaller one was starving the engine of air and causing the intake hose to collapse under full boost. ![]() Click image to enlarge Waffleboard mount as made by D44: ![]() Click image to enlarge ![]() Click image to enlarge Truck sees the light of day out of the workshop: ![]() Click image to enlarge ![]() Click image to enlarge Front number plate mount: ![]() Click image to enlarge Some finished pictures: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Hi-Lift Mount: ![]() Click image to enlarge Bigger Cyclone Top (I believe this one is 10 inches in Diameter): ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Genesis Battery Monitor Mount: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Final Vehicle: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge And in good company with Dad’s 90: ![]() Click image to enlarge Cheers Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Series 1 86" |
Brilliant!
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 ![]() ![]() |
Like others have said amazing build great to see
Thanks ![]() |
Started reading page 3 of this thread, quickly moved to page 1 to then read the entire thread.... One word, WOW!!!
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
