Home > My Defender > What Did You Do In Your Defender Today |
Bought and fitted a new headlight switch because they wouldn't work last night then as they still wouldn't work I found the loose connection that just needed pushing back in maybe I should look before buying parts
11th Sep 2014 11:45am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
fitted jw speaker headlights - bought from www.mobilecentre.co.uk
Click image to enlarge |
11th Sep 2014 1:43pm |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Why when you just get every thing sorted does something else go wrong .........
12th Sep 2014 9:54am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Law of sod
12th Sep 2014 10:10am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
yeah,for every pound I've spent modding mine I've spent £30 fixing it,lol. Pov.spec,ftw. 2006, 110,TD5.
12th Sep 2014 11:03am |
Completed the lights height correcting today as per above I only did the Speakers low beam two weeks ago. Today I also corrected the level of one of the aux high beam halogen lights which had been pointing a bit too high. Again, did it the simple way, park the truck on level ground in front of a wall and check if both the beams of the aux lights are the same, if not as was the case here, it just takes a screwdriver to correct the aux lamps up or down. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Oh, and before that, ran the SVX through the car wash tunnel and properly towel dried it thereafter, and let it further dry out in todays sunny breezy weather. Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
12th Sep 2014 4:22pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
SNAP... Fitted same today, except for the side intake, as I already have a Snorkel fitted... Great quality from Flatdoguk.com... And also like the replacement Torx screws and driver, nice touch... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
12th Sep 2014 6:36pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20495 |
Trailer lighting issues today, notice the lights going nutty today.
Defender it's self is fine but trailer attached it goes odd. Although fiddled about and it worked fine once I abandoned my trip tonight to get stuff. My guess is poor contact, shall have to clean the plug up Defender side and check the rear fot corrosion. Both are high in my suspicion as suspects. |
12th Sep 2014 6:45pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Big update for me
Monday fitted led fog lights and wired them to landrover aux 2 switch, also fitted and wired up a 44" led lightbar to the roof and fitted a led work light for my winch yesterday i removed the genuine side steps as they resembled swiss cheese, then set about removing the std sills ( not fun) as they havent being touched in 10 years. after adding to the swear jar countless times. Once this was done i fitted some tree sliders Today i fitted a new xs cubby box from matt, and discovered td5's have a larger cubby box than pumas, also i fitted a galv transmission guard, extended the fuel tank breather 2004 TD5 Defender 90 xs station wagon |
12th Sep 2014 7:37pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Fitted a relay to the lights. (although my existing lights had 14v across them so doubt I'll see a light upgrade but at least the switch may not burn out)
Did a few more of the SS bolts Replaced the Screen hinge gasket to cure a leak |
13th Sep 2014 2:57pm |
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 |
What tree sliders did you go for? 2007 (57) Defender 90 (Sold) Looking for another to replace it. The road less travelled.... is a muddy one! |
13th Sep 2014 3:21pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Went shopping for house extension stuff.
Had over 200 quarry tiles in the back and 3 x carpet sample packs ! For the first time my heavy duty twin coil suspension had some work to do |
13th Sep 2014 6:15pm |
OldhamLandy Member Since: 17 Oct 2013 Location: somewhere Posts: 164 |
Fitted a Nakatanenga rear door stay - no more door hitting me in the backside every time I park on an incline
Also fitted an Entreq Snow Cowl which looks the dogs nads 2016 Defender 90xs SW - Santorini Black with Silver Pack 2014 Defender 90xs SW - Corris Grey with Santorini Black Roof |
13th Sep 2014 7:07pm |
i went for the safari equip ones as they are galvanised before powdercoated 2004 TD5 Defender 90 xs station wagon |
14th Sep 2014 10:30am |
