Home > Technical > puma diff noise
Page 2 of 3 <123>
MK
heinrichnel wrote:
Hi,
I have a 2008 110 with the same issues. Had a whining noise coming from the rear, Stealers said it was the transfer box and replaced it at 19000km. Noise did not disappear, then they order a new diff, had to be shipped all the way from England, don't carry it in stock in South Africa???? Replaced the rear diff, which I did thought was the issue, now much better, still a slight wine deceleration from 120 to 100, but much better!
So my question, good idee to fit an ARB locker in the rear? Should also solve the problem, as far as I am aware it is a better quality 3rd member than the LR one, why I am considering this is my factory warranty expires in couple of months and I don't have the money to keep on replacing the diff every year!
Heinrich
YouŽll still have the same pinion and crown though. Puma 110" SW
Post #30008 17th Apr 2010 5:22pm
Tim seymour
Australia
yes my defender goes in on monday for number 5. landrover will change the diff again and use a different oil plus have been told to check the diff houseing and if need be a compleat rear end change . cheers ps will let you know the out come Razz
Post #31114 30th Apr 2010 9:16am
mhasting2004
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
You are not alone... Mine goes in for number 3 this week! Who knew that diffs are expendable items that you change when you do the oil! I'm getting concerned that this may become a yearly ocurrance
Post #31249 2nd May 2010 11:45am
Tim seymour
Australia
hi well thay changed the diff diffrent oil still the same the dealers are not happy . the next thing is to replace the hole rear end that will be number 6 .will let you know how i go Big Cry
Post #31699 7th May 2010 11:37pm
MK
Unbelievable! have they check on the chassis geometry? (in case it is totally FU). Must be a faulty diff casing. I would also ask for new halfshafts, bearings, etc.
Somewhere in this forum Dave Aschcroft gave an explanation about dodgy factory setup on later LR diffs. Puma 110" SW
Post #31702 8th May 2010 2:22am
Tim seymour
Australia
hi well i am back .thay replaced wheel bearings ,transfer box its been there for three week now and still not fixed Big Cry
Post #33693 4th Jun 2010 9:01am
pom
just reading your thread and am amazed. I was under the impression that Landrovers have been built for 40+years and should be engineering wise top notch.
Putting diffs in one after the other with no effect would tell me, who knows Censored all about grease monkeying, that it aint the diff at fault ?
Has the QA at Landrover got this bad with the launch of the puma derivative or has it allways been ropey ?
For comparison I have an Audi and frequent an Audi forum much like this one, obviously there are many more audi's on the road than Landrovers, and there are nowhere near the quantity of tales of woe like on here. It does make you wonder whats going wrong at LR.
Pom
Post #33696 4th Jun 2010 9:26am
roel
Next to a few LR's my wife has a 2006 Volvo V50 next to the regulare service it has been to the dealer regulary because of a irritating noise. They have changed heatshields and other parts. the noise sounded to come from the right front of the car. The problem was it comes and goes it's not always there.
A few weeks it ago it was bad again and this time they may have found it. It was the rearview mirror holder that vigrated against the windscreen. I has been quiet since. I took only 4 years to find it. Whistle
The moral of the story is that the sound may come from somewhere completely different. Roel
2003 90 Td5 (2009-now)
Post #33784 5th Jun 2010 9:07pm
jst
an ARB is a stronger than OE rpart yes. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #34097 10th Jun 2010 9:19am
Tim seymour
Australia
well thay have fixed it at last . it was the diff all along .apparently it was the diff set up now it is as quite as a mouse .it took 6 diffs 1tranfer case 1set of wheel bearings and about 8 bloody weeks to fix but i am very happy now Razz
Post #35557 4th Jul 2010 10:32am
ashtrans
Site Sponsor
Hi,
I am not surprized,
we have had new diffs and had to strip them, reshim the pinion as they were too tight and reset the backlash as they had zero , they need min 4 thou,
I had an australian dealer emailing me last week who wanted to buy some of our ring and pinions to put in a customers new car as they had lost faith in the landrover diffs, I wonder if this was for your car,
Dave Dave
Post #35660 5th Jul 2010 10:38pm
MK
[quote="ashtrans"]Hi,
I am not surprized,
4? Puma 110" SW
Post #35663 6th Jul 2010 12:12am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Mines been in for the past week at the dealers, they still have it - they fitted a couple of exchange diffs - dsmr noise, now Land Rover wont let the dealer release it until they have been sent a new unit.
it does mean that now they have given me a RR sport to chav around in
Post #36653 20th Jul 2010 6:43pm
MK
pay attention with "new units" Puma 110" SW
Post #36676 21st Jul 2010 1:41am
Tim seymour
Australia
yep mine still going well .had some noise from the handbrake the outher day the klonking when going really slow.the handbreak drum might be a bit out of round. thay replaced the tranfer case with new handbreak on it.so i ran the defender with handbrake on for a few km and it seems fine now cheers tim ps i didnt get range rover sport i got an old subaru wagon Razz
Post #36677 21st Jul 2010 7:16am
Page 2 of 3 <123>
