Home > Technical > puma diff noise |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 |
yes my defender goes in on monday for number 5. landrover will change the diff again and use a different oil plus have been told to check the diff houseing and if need be a compleat rear end change . cheers ps will let you know the out come
30th Apr 2010 8:16am |
mhasting2004 Member Since: 07 Dec 2008 Location: Gosford Posts: 29 |
You are not alone... Mine goes in for number 3 this week! Who knew that diffs are expendable items that you change when you do the oil! I'm getting concerned that this may become a yearly ocurrance
2nd May 2010 10:45am |
hi well thay changed the diff diffrent oil still the same the dealers are not happy . the next thing is to replace the hole rear end that will be number 6 .will let you know how i go
7th May 2010 10:37pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
Unbelievable! have they check on the chassis geometry? (in case it is totally FU). Must be a faulty diff casing. I would also ask for new halfshafts, bearings, etc.
Somewhere in this forum Dave Aschcroft gave an explanation about dodgy factory setup on later LR diffs. Puma 110" SW ............................................................. Earth first. Other planets later |
8th May 2010 1:22am |
hi well i am back .thay replaced wheel bearings ,transfer box its been there for three week now and still not fixed
4th Jun 2010 8:01am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
just reading your thread and am amazed. I was under the impression that Landrovers have been built for 40+years and should be engineering wise top notch.
Putting diffs in one after the other with no effect would tell me, who knows all about grease monkeying, that it aint the diff at fault ? Has the QA at Landrover got this bad with the launch of the puma derivative or has it allways been ropey ? For comparison I have an Audi and frequent an Audi forum much like this one, obviously there are many more audi's on the road than Landrovers, and there are nowhere near the quantity of tales of woe like on here. It does make you wonder whats going wrong at LR. Pom |
4th Jun 2010 8:26am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Next to a few LR's my wife has a 2006 Volvo V50 next to the regulare service it has been to the dealer regulary because of a irritating noise. They have changed heatshields and other parts. the noise sounded to come from the right front of the car. The problem was it comes and goes it's not always there.
A few weeks it ago it was bad again and this time they may have found it. It was the rearview mirror holder that vigrated against the windscreen. I has been quiet since. I took only 4 years to find it. The moral of the story is that the sound may come from somewhere completely different. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
5th Jun 2010 8:07pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8093 |
an ARB is a stronger than OE rpart yes. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th Jun 2010 8:19am |
well thay have fixed it at last . it was the diff all along .apparently it was the diff set up now it is as quite as a mouse .it took 6 diffs 1tranfer case 1set of wheel bearings and about 8 bloody weeks to fix but i am very happy now
4th Jul 2010 9:32am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 258 |
Hi,
I am not surprized, we have had new diffs and had to strip them, reshim the pinion as they were too tight and reset the backlash as they had zero , they need min 4 thou, I had an australian dealer emailing me last week who wanted to buy some of our ring and pinions to put in a customers new car as they had lost faith in the landrover diffs, I wonder if this was for your car, Dave Dave |
5th Jul 2010 9:38pm |
[quote="ashtrans"]Hi,
I am not surprized, we have had new diffs and had to strip them, reshim the pinion as they were too tight and reset the backlash as they had zero , they need min 4 thou, 4? Puma 110" SW ............................................................. Earth first. Other planets later |
5th Jul 2010 11:12pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
Mines been in for the past week at the dealers, they still have it - they fitted a couple of exchange diffs - dsmr noise, now Land Rover wont let the dealer release it until they have been sent a new unit.
it does mean that now they have given me a RR sport to chav around in |
20th Jul 2010 5:43pm |
pay attention with "new units" Puma 110" SW
21st Jul 2010 12:41am |
yep mine still going well .had some noise from the handbrake the outher day the klonking when going really slow.the handbreak drum might be a bit out of round. thay replaced the tranfer case with new handbreak on it.so i ran the defender with handbrake on for a few km and it seems fine now cheers tim ps i didnt get range rover sport i got an old subaru wagon
21st Jul 2010 6:16am |
