Home > Technical > puma diff noise
Page 3 of 3 <123
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Help, Whine
Got a similar noise today, whilst on motorway speed going from 70 mph down to about50, loud whine, sounds like a plane coming into land, noise still there then when accelerating back to 70, is this the diff? sounds like its coming from behind me
Post #54124 20th Jan 2011 3:46pm
MK
Most likely to be the crown-pinion out of spec. Yours is a 2010?
Whistle Puma 110" SW
Post #54128 20th Jan 2011 3:52pm
kingofthesparks
yes oct 2010, is this a quick fix or will the dealer need it days?
Post #54129 20th Jan 2011 3:53pm
MK
It is a full day job for a well trained person. A couple of days if nothing is severely worn out. Puma 110" SW
Post #54134 20th Jan 2011 4:33pm
kingofthesparks
its only done 4000 miles Rolling Eyes
Post #54143 20th Jan 2011 5:55pm
MK
Well. Dono what to say as it is a LR. Just take it to a capable dealer. Puma 110" SW
Post #54155 20th Jan 2011 7:22pm
Tim seymour
Australia
hi mine is good now after about 7 diff and alot of trouble thay got it right there is still a slight noise but i can live with that after all it is a defender and thay make noises cheers tim Smile Cess the Taswegian
Post #54270 21st Jan 2011 7:15am
Aaron Kendon
Australia 2010 Defender 110 Puma 2.4 SW Alpine White
Yep exact same model and year, my diff is definately noisy in overun. Mate have i had dramas with mine. 5 egr valves, a new engine, panels coming away from under passengers seat, front diff burnt oil, you name it mine has done it. Not happy any more with it, my first brand new car ... did have a 98 110 defender that was brilliant.. go figure... Your not alone. Puma Growls At Me Constantly
Post #151102 19th Jun 2012 10:02am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
note that LR changed the teeth design on the C&R of the back diff, make sure you get the latest
pics here:
http://www.defender2.net/forum/topic13545.html
If drivetrain backlash becomes an issue suspect diff also, found them to be the main cause of it (not R&P)
2 cents
Smile
I you have identical sound on acceleration, check wheelbearings first, R&P tend to make more sound on overrun (or none under acceleration)
Post #151107 19th Jun 2012 10:21am
Aaron Kendon
Well took her in today, they are replacing both diffs, and both rear axles... Hmmm they said that the latest design is going in and shouldn't be a prob any more. Thaey also tell me that they have had a few with this issue, what exactly goes wrong is a mystery, but there is not much to a diff anyways. I am a diesel mech by trade and i personally tink that the carrier flexs ever so slightly and results in pinion to crown wheel tooth contact change which will cause excessive whine in overun and in some casses under load. It is quite simple to fix and if you want dead quiet running, have the crownwheel and pinion lapped by a machine shop.. But hey if its still under warranty let someone else do it ... Puma Growls At Me Constantly
Post #151296 20th Jun 2012 10:18am
Naks
wow, sounds like a good dealer.
Have them check the clutch while they're at it Wink --
Post #151301 20th Jun 2012 10:30am
Aaron Kendon
Ummm already done that at 3000 klms, the front of the g/box fell to bits and took out the clutch etc. I would put my foot on the clutch and it would bang away. ... Sorry forgot to mention that in my firts post.. Puma Growls At Me Constantly
Post #151304 20th Jun 2012 10:35am
Aaron Kendon
ULR port Melbourne Australia, i must admit they do help as much as possible... Havn't asked for a new one yet, but i nearly do anyway.. I havn't been in serious off road yet too scared it will break. Puma Growls At Me Constantly
Post #151305 20th Jun 2012 10:38am
Dealers will only change the diff now, ie swap it for a complete new (or more likely reconditioned) unit. There appear to be some issues with diff build quality from LR, and the ideal solution would be to set the diff up properly rather than simply replace one bad diff with another.
Setting up a diff is not difficult but is not a job for the faint-hearted; there are several other threads on the subject.
Swapping a diff out is a quick job (you can do it in less than an hour for the rear, perhaps three for the front), stripping and adjusting one takes longer depending on skill, parts and experience.
Post #151320 20th Jun 2012 11:36am
Aaron Kendon
Yes i agree. I might pull the new ones out and re-check.... doubt it. Laughing Puma Growls At Me Constantly
Post #151443 21st Jun 2012 7:22am
Page 3 of 3 <123
