Page 729 of 1380 <123 ... 728729730 ... 137813791380>
ericvv
Visited Neuchatel today, parked the truck on a very very steep slope, steeper than it looks in the picture. I had to pull the parking brake to a few more than the 3rd click I usually do, but it is confirmed, my parking brake works very well. Thumbs Up
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #356287 7th Sep 2014 4:37pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Spent two hours trying to change a set of brake pads, inboard pistons refused to move on one corner so had to set about removing the new set on opposite corner that were no problem. Banging Head Banging Head Censored
Also found that four out of five locking wheel nuts are missing. Banging Head Censored
Fitted the Mud stuff deflector to the heater. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #356290 7th Sep 2014 4:45pm
mk1collector
4 out of 5 lockers missing? Shocked could someone be lining up to nick your wheels?
Post #356293 7th Sep 2014 4:49pm
mk1collector
Replaced the front axle oil so that's every oil done for the year Mr. Green
Post #356296 7th Sep 2014 4:50pm
ARC99
The possibility is quite high as in the last week someone has tampered with the outside security light, I will have to get some replacements ordered in the morning. Don't make old people mad.
Richard
Post #356317 7th Sep 2014 6:24pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Fitted the roof rack I purchased from a forum member, two issues, the wind deflector caught the sunroof and drivers doors was so tight to the top of frame. Had door looked at by an Indie and now I've adjusted it so not catching the gutter clamp. Removed wind deflector so rack lined up correctly. Painted the brackets black and fitted the number plate to the rack, hoping I'd not need to modify the wind deflector. Went up and down the 329 and no wind noise so no need to modify and refit the deflector. Thumbs Up _______________________________
Puma Defender 90
Post #356335 7th Sep 2014 7:10pm
nitram17
david mitchell wrote:
Called out the plumber to fix my water pump and he arrived in this new 90. Thumbs Up
What colour is that 90?
Post #356344 7th Sep 2014 7:24pm
Venomator
To Black - Or Not?
So, having spent a good couple of hours, and then some, stripping the paint from and cleaning my old Tow Ball, with a view to re-priming and painting it black again... Rolling Eyes
I rather like it stripped nekkid and unpainted and am now in two minds... Big Cry
Whaddya'll think... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #356349 7th Sep 2014 7:35pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Made the most of the sunshine with a wee spot of therapeutic cleaning Cool
 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #356352 7th Sep 2014 7:38pm
Jomara - Very nice. Thumbs Up Cool Thumbs Up
Venomator - I have the same NAS step as you and tow ball and hitch.
I painted mine without primer originally to see what it looked like, I liked it but quickly looked tatty.
I stripped it back and fitted again and left it, I don't mind it bare now.
Main reason being that however well you paint it, it will wear WILL make it worn and tatty.
I also have mine fitted in the lower position, if ever you tow you'll find it'll be far too high in that position.
Even at the lowest position I find that it's still a touch high for my Ifor but not enough to worry about, especially for a <750kg trailer.
Post #356359 7th Sep 2014 7:55pm
mk1collector
Oh my Bow down
Post #356363 7th Sep 2014 8:04pm
Venomator
Thanks Steve, really appreciate the feedback... Bow down
And thanks for the towing tips, being new to Defender Life, I was not sure which of the pair to use (the tow ball was loose when I picked the truck up!), so it's useful to know the lower pegs are the ones to use... Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #356369 7th Sep 2014 8:09pm
jomara
Thanks guys Thumbs Up Thumbs Up
A NAS step is on my wish list, but I'm not 100% sure about the tow all height as I regularly tow my 22' tilt bed trailer, do you have a drop plate on yours Steve? 2014 110 2.2TDCi XS Station wagon
Post #356376 7th Sep 2014 8:19pm
Veno - Thumbs Up Thumbs Up
Jomara - No drop plate on mine, but others have used one.
The towing nose height on mine on an 8ft trailer is a touch high but not too bad, I'm not too worried with a light trailer.
On a big trailer with more length it would be more of an issue, just use a thick regular drop plate.
Post #356380 7th Sep 2014 8:26pm
jomara
Cool, my trailer is a beaver tail and catches kerbs and rocks already.
Thumbs Up 2014 110 2.2TDCi XS Station wagon
Post #356383 7th Sep 2014 8:28pm
