Home > Maintenance & Modifications > Why can't I flash?
ZeDefender
Why can't I flash?
Advice please Mr. Green
I just noticed today that my "Lichthupe" (light horn/flasher) doesn't work when I pull back on the headlight switch. Both lights function normally (low and high beam) so can it only be the switch that's knackered or could something else be at fault?
Matt Tell someone you love them today because life is short.
Post #355708 4th Sep 2014 7:39pm
Does the horn work?
Post #355709 4th Sep 2014 7:40pm
ZeDefender
Yes Smile Tell someone you love them today because life is short.
Post #355710 4th Sep 2014 7:44pm
Eduardo
ZeDefender
If you take out the upper steering column shroud you will gain access to the switch (easy job).
In the rigth side you will be able to see the contacts that overrride the ligth switch to make the light flash.
The contact that is near to the steering wheel should be live and the other make the contact. very easy to see if you move the switch. Try there first.
Regards Eduardo
Post #355726 4th Sep 2014 8:17pm
ZeDefender
Many thanks Thumbs Up Tell someone you love them today because life is short.
Post #355751 4th Sep 2014 8:55pm
landy andy
Don't you have yours on relays?
Post #355779 4th Sep 2014 10:20pm
ZeDefender
Yes but I checked the original wiring and it's the same. Tell someone you love them today because life is short.
Post #355790 4th Sep 2014 11:15pm
