![]() | Home > Maintenance & Modifications > Why can't I flash? |
Advice please
![]() I just noticed today that my "Lichthupe" (light horn/flasher) doesn't work when I pull back on the headlight switch. Both lights function normally (low and high beam) so can it only be the switch that's knackered or could something else be at fault? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20616 ![]() ![]() |
Does the horn work?
Yes
![]() But shout it at them in German because life is also terrifying and confusing... |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
ZeDefender
If you take out the upper steering column shroud you will gain access to the switch (easy job). In the rigth side you will be able to see the contacts that overrride the ligth switch to make the light flash. The contact that is near to the steering wheel should be live and the other make the contact. very easy to see if you move the switch. Try there first. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Many thanks
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5806 ![]() ![]() |
Don't you have yours on relays?
Yes but I checked the original wiring and it's the same. Tell someone you love them today because life is short.
