Home > Puma (Tdci) > puma alarm fault |
It's probably the Landrover spider
10th Aug 2014 11:59am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Anything else happen when alarm goes off?
Doors unlock when it sounds? Does it do it more if it rains? Have you tried putting tape over the volumetric sensor? If it gets really bad you can lock with the key, and alarm will not be set but immobiliser will be Andy |
10th Aug 2014 1:32pm |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 |
Could it be the battery? Our Def is the main driver but Mrs GLP's occasional good weather car (convertible) has to be permanently on charge when not regularly used or the alarm triggers when the voltage drops. Cheers, Guy.
10th Aug 2014 4:07pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
I think the 'popular' problem is wiring to door switches. When the wiring is failing I think this is one of the tell tales.
Stand to be corrected though. Good luck in resolving. |
10th Aug 2014 4:32pm |
Daz Member Since: 10 Aug 2014 Location: west yorks Posts: 46 |
Hi thanks for reply , Heres what ive done so far , Checked door switches and replaced passenger door one cos it was sticking a little , I didn't think of putting tape over sensor but ive done it this afternoon , Alarm has been set now since 2oclock and has not gone of yet but normally waits till middle of night . IS it possible to disable alarm and immobiliser and get a thatcham Clifford or cobra alarm fitted . I will keep you all posted what happens next , Cheers daz .
10th Aug 2014 6:47pm |
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 |
I had the same problem on my Defender 130 MY2007
I searched for one year. It was a thread that went to the roof light which pinched at the dashboard. Since one month, more problems. :D |
12th Aug 2014 7:36am |
DSB Member Since: 02 Mar 2014 Location: Rutland Posts: 55 |
The alarm in my MY13 90 goes off occasionally when you unlock, get in and turn the ignition. You have to go through a series of unlocking/locking with the fob to get it to reset. Its very random, and the alarm is loud! Intend to get it looked at when next in for warranty work or service.
14th Aug 2014 8:38am |
Hi all thanks for replys , Since putting some tape over the sensor the alarm seems to be behaving so im guessing its the sensor that's at fault or the landy spider that I haven't seen yet coming out to play .
cheers daz .. |
14th Aug 2014 8:33pm |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 |
Hi Daz Ive a MY09 and mine was going off now and then , traced it to a knackered dieing Battery ,Fitted new battery not happened since, main battery not the Fob ones
22nd Aug 2014 9:54am |
Hi 110John how did you trace it to the battery that was at fault , I thought it was sensor that was at fault but its gone off twice since . Is it possible to have the alarm completely turned off or removed and get a thatchem alarm fitted .. cheers daz .
27th Aug 2014 7:40pm |
Hi Daz I mean the main battery like not enough power to start or just start on turn over . Flat battery in the morning or a few days later Another thing to look at is Parasitic current Drain ie whats draining the battery after switch off youll be surprised what still pulls current from the battery some car radios even switched off can pull 160 milliamp switched off, a tracker will pull nearly an amp so on a 90 amp battery 3 days and your flat, if your alarm the 10 AS sees a voltage drop it will activate, a current draw tester is around a £10 or less well worth its salt it cured my battery drain by identifying where my current drain lay . so are you having to charge your battery often ? or is it current drain process of illimination it could also could just be a faulty 10 AS unit, my problem was Parasitic current drain items taking power from the battery even everything switched off alarm seeing voltage drop activating the alarm Finding the actual cause is a ball ache because no two faults the same but heres a start so have you added any new electrics at all ?, how olds the landy/battery ?
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain |
27th Aug 2014 11:37pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6095 |
Why not plug in a nanocom type thing and reduce the sensitivity of the sensor?
28th Aug 2014 12:48pm |
[quote="Mongolia"]I had the same problem on my Defender 130 MY2007
I searched for one year. It was a thread that went to the roof light which pinched at the dashboard. Since one month, more problems. :D[/quote] Sorry Since 2 monthes, NO more problems |
28th Aug 2014 4:48pm |
