Home > Puma (Tdci) > puma alarm fault
Daz
United Kingdom 2007 Defender 90 Puma 2.4 HT Java Black
puma alarm fault
Hi has anyone got any ideas what could be wrong with the alarm on my 2007 hard top 90 , When I set the alarm everything seems ok for a few hours then for no reason the alarm goes of , it has the interior sensor fitted above drivers head . Is it a common fault or is it a case of having to go get it plugged in to diagnostics . Ive had it a month and its been going of now for a week on and off . Its really annoying in middle of night . Is there a workshop manual available for the puma yet ive seen the cd versions on ebay but the feedback doesent look good saying they don't download . cheers daz ,.
Post #350753 10th Aug 2014 11:35am
mk1collector
It's probably the Landrover spider Whistle
Post #350755 10th Aug 2014 11:59am
landy andy
Anything else happen when alarm goes off?
Doors unlock when it sounds?
Does it do it more if it rains?
Have you tried putting tape over the volumetric sensor?
If it gets really bad you can lock with the key, and alarm will not be set but immobiliser will be Thumbs Up
Andy
Post #350773 10th Aug 2014 1:32pm
glpinxit
Could it be the battery? Our Def is the main driver but Mrs GLP's occasional good weather car (convertible) has to be permanently on charge when not regularly used or the alarm triggers when the voltage drops. Cheers, Guy.
Post #350810 10th Aug 2014 4:07pm
Caterham
I think the 'popular' problem is wiring to door switches. When the wiring is failing I think this is one of the tell tales.
Stand to be corrected though.
Good luck in resolving.
Post #350815 10th Aug 2014 4:32pm
Daz
Hi thanks for reply , Heres what ive done so far , Checked door switches and replaced passenger door one cos it was sticking a little , I didn't think of putting tape over sensor but ive done it this afternoon , Alarm has been set now since 2oclock and has not gone of yet but normally waits till middle of night . IS it possible to disable alarm and immobiliser and get a thatcham Clifford or cobra alarm fitted . I will keep you all posted what happens next , Cheers daz .
Post #350841 10th Aug 2014 6:47pm
Mongolia
France
I had the same problem on my Defender 130 MY2007
I searched for one year. It was a thread that went to the roof light which pinched at the dashboard. Since one month, more problems. :D
Post #351174 12th Aug 2014 7:36am
DSB
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Indus Silver
The alarm in my MY13 90 goes off occasionally when you unlock, get in and turn the ignition. You have to go through a series of unlocking/locking with the fob to get it to reset. Its very random, and the alarm is loud! Intend to get it looked at when next in for warranty work or service.
Post #351538 14th Aug 2014 8:38am
Daz
Hi all thanks for replys , Since putting some tape over the sensor the alarm seems to be behaving so im guessing its the sensor that's at fault or the landy spider that I haven't seen yet coming out to play .
cheers daz ..
Post #351658 14th Aug 2014 8:33pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Hi Daz Ive a MY09 and mine was going off now and then , traced it to a knackered dieing Battery ,Fitted new battery not happened since, main battery not the Fob ones
Post #353083 22nd Aug 2014 9:54am
Daz
Hi 110John how did you trace it to the battery that was at fault , I thought it was sensor that was at fault but its gone off twice since . Is it possible to have the alarm completely turned off or removed and get a thatchem alarm fitted .. cheers daz .
Post #354045 27th Aug 2014 7:40pm
Daz
Post #354046 27th Aug 2014 7:40pm
110 John
Hi Daz I mean the main battery like not enough power to start or just start on turn over . Flat battery in the morning or a few days later Another thing to look at is Parasitic current Drain ie whats draining the battery after switch off youll be surprised what still pulls current from the battery some car radios even switched off can pull 160 milliamp switched off, a tracker will pull nearly an amp so on a 90 amp battery 3 days and your flat, if your alarm the 10 AS sees a voltage drop it will activate, a current draw tester is around a £10 or less well worth its salt it cured my battery drain by identifying where my current drain lay . so are you having to charge your battery often ? or is it current drain process of illimination it could also could just be a faulty 10 AS unit, my problem was Parasitic current drain items taking power from the battery even everything switched off alarm seeing voltage drop activating the alarm Finding the actual cause is a ball ache because no two faults the same but heres a start so have you added any new electrics at all ?, how olds the landy/battery ?
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Post #354101 27th Aug 2014 11:37pm
Why not plug in a nanocom type thing and reduce the sensitivity of the sensor?
Post #354194 28th Aug 2014 12:48pm
Mongolia
France
[quote="Mongolia"]I had the same problem on my Defender 130 MY2007
I searched for one year. It was a thread that went to the roof light which pinched at the dashboard. Since one month, more problems. :D[/quote]
Sorry
Since 2 monthes, NO more problems
Post #354221 28th Aug 2014 4:48pm
