Home > Tdi > an other smoky 300tdi
lacrits68
Sweden
hello!
My 130 is doing some smoking
at 2000rpm (app) its smoking some blue and when flooring it smoke gets black.
When driving it gives an constant black smoke. There is no oil consumption, no blowby or no coolant loss.
I removed injectors for service but is there anything elso to look after?
EGR is blanked, new filters ( fuel, air), sedimenter cleared, new silicon turbohoses ( clean hoses and intercooler too), ne oil. miles on the clock 186 000mile/300 000tkm. No loss of power and MPG 26.
Im lost help me!
//Jan
Post #342402 3rd Jul 2014 6:03am
g-mack
im no expert but i think black smoke is over fueling, or not enough air in the mix. My 109 thread
my youtube channel
Post #342435 3rd Jul 2014 9:00am
shaggydog
Check your timing belt, Timing may be out causing to early or late injection.
Check your injector pump for signs someone has "tweeked" it and got it wrong. May be as simple as just resetting to factory settings.
Is your turbo waste gate moveable? If its not closing then turbo isn't keeping up with fuel delivery and so the fuel is not being burnt.
Have you checked your oil levels? if it is over full of oil can cause catastrophic failure as it can drink its own sump and you wont be able to stop it.
Also do you have excessive turbo play? If so it could be pumping oil straight into the inlet and exhaust which will make smoke.
Post #342566 3rd Jul 2014 4:58pm
lacrits68
Sweden
now i have...! Big Cry
case closed?
Post #342568 3rd Jul 2014 5:09pm
shaggydog
Afraid so. Neutral
Post #342574 3rd Jul 2014 5:49pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Get it sorted soon as.
My turbo went very suddenly a year or so back, dumping all the oil down the exhaust in a matter of seconds and ended up with this:
Post #342583 3rd Jul 2014 6:30pm
lacrits68
Sweden
hello!
I will...its probably gona be one of these kits ( nr1 kit)
http://www.mdengineering.co.uk/pdf/112~TGV...%20Tdi.pdf
cheers
Jan
Post #342676 4th Jul 2014 4:58am
g-mack
Post #343755 8th Jul 2014 5:06pm
lacrits68
Sweden
problem solved...new (actualy 2nd hand) turbo, new de cat downpipe, egr blanked, new injectors and timing checked and adjusted...!
Goes lite a recer and is nowdays an "non smoker" Very Happy
thans all!
//Jan
Post #349338 3rd Aug 2014 9:09pm
shaggydog
Good to Hear Thumbs Up
Post #349352 3rd Aug 2014 9:20pm
